03-21-2016, 09:12 AM | #21 | |
Re: where to get 1952 Ford Truck motor mounts?
03-21-2016, 11:37 AM | #22 |
Try All Ford Parts in Campbell, Ca. Ph# 1-800-532-1932. They have a lot of NOS parts.
03-21-2016, 04:17 PM | #23 | |
It is perfectly useless to know the right answer to the wrong question. |
03-25-2016, 02:19 PM | #24 |
I measured my bolts. See below. I imagine a 3-1/2"-long 1/2"-dia. bolt with a piece of 1/2" ID, 5/8" OD tubing slipped over it would work if you don't have a lathe.
'52 F-1, EAB flathead |
03-26-2016, 07:56 AM | #25 | |
Jeff
10-28-2017, 04:40 PM | #26 |
10-29-2017, 09:28 AM | #27 |
I use aircraft bolts to control overall length and thread length purchased through Aircraft Spruce. The AN8 will work for 1/2" diameter and the length dash numbers are in 1/8" intervals. The tubing for the step is out there. it just has to be cut to mach the step on the OEM shoulder bolt. This workks well and is starting with new metal. So many of the original parts are badly rusted and OEM parts are getting harder to source every year. I fear a person would have to have a lathe and a mill to fabricate ones like the original and even then they should be plated to slow the corrosion.
10-29-2017, 01:26 PM | #28 |
The lower rubber piece has a large diameter washer molded into it. The bolts come up from below, into the water pump foot. I used a washer under the castle nuts.
08-13-2020, 08:36 AM | #29 |
Since we are on the subject of 52 F1 flathead v8 engine mounts.
In my 52 F1 pickup, my front cross member has been butchered to fit in a different radiator, to go along with the 351 Cleveland in my pickup. I want to return my pickup to standard. I have an 8BA/8RT to go back in my pickup, and have the correct 1952 F1 pickup motor mount brackets etc to suit. I also want to replace my front cross member. Are all 48 - 52 F1 front cross members the same?? and thus compatible with the 52 engine mount brackets?? Thanks |
08-13-2020, 09:53 AM | #30 |
Yes, they are the same front cross member for 1948 through 52 F1, 2, & 3 plus the parcel delivery.
Don't hesitate to start a new thread. It will draw attention to your needs quicker that way. |
