Old 05-22-2010, 09:53 PM   #1
carcrazyjohn
Default 32 wishbones how to tell the difference
I have 32 ford wishbones according to the bible .Now what are the measurements....Did the reuse the casted part with the ball in 34 .And hello Ryan ......
carcrazyjohn is offline   Reply With Quote
Old 05-22-2010, 10:40 PM   #2
Andy
Default Re: 32 wishbones how to tell the difference
I think weld to weld is 45 on a 32 and 43 on a 33-34. If no one verifies, I will check tomorrow. I believe the ball forging is the same 32-34. Some of the A forgings were quite simular except bowed. I have considered flatening an A to fix a 32.
Andy is offline   Reply With Quote
Old 05-22-2010, 11:01 PM   #3
carcrazyjohn
Thanks
Old 05-23-2010, 12:25 AM   #4
Flathead Fever
Flathead Fever's Avatar
I'm pretty sure the '32 wishbone is longer than the '33-34. Its the opposite of what you would think.
Jerry
Old 05-23-2010, 06:18 AM   #5
PeteVS
PeteVS's Avatar
If you're doing a "stretch," say lengthening an A to use in a '32, or a "shrink," say '32 to '33 / '34, you'll have to heat and bend the center forging to get the perch to perch spacing right with the new leg length. For this reason, I think that the '32 center forging might be a different forging from the '33 / '34. Either that or they might have tweaked them at the factory. (Anyway, I have a nice '33 / '34 wishbone that I'd like to swap for a '32 if anyone is in the opposite boat.)
Old 05-23-2010, 07:26 AM   #6
carcrazyjohn
Saw that thread ,Does anybody have a set they can measure 32 ,,,,,,
Old 05-23-2010, 07:40 AM   #7
PeteVS
PeteVS's Avatar
A while back, I did some measuring with a tape measure. (My numbers might be off a bit.)
For a '32, I measured 44" from centerline of ball to centerline of axle (measured along centerline of car.)
For a '33/'34, I measured 41-3/8"
Another time, I measured centerline of ball to centerline of perch pin hole at 47-3/4" for a '32 and 45-1/2" for a '33/'34.
Both cases, centerline of perch pin hole to centerline of perch pin hole was 37"-37-1/4", but it's easy to tweak that during assembly.
Hope this helps.
