Old 08-16-2011, 03:12 AM   #1
Fairlane500
Fairlane500's Avatar
Default Radius rods
Can any one tell me if 46-48 rear radius rods are compatible with 1939 ford axle? Thanks
Life is not a dress rehearsal...
Fairlane500 is offline   Reply With Quote
Old 08-16-2011, 06:15 AM   #2
PeteVS
PeteVS's Avatar
Default Re: Radius rods
The point where they bolt to the ends of the axle housings and backing plates are the same. But, due to the fact that the '39 axle housings are shorter, the back ends of the radius rods will have to be heated and bent slightly outwards so that the front ends will come to the proper point where they bolt to the torque tube. Once that is taken care of, the front ends will have to be heated and bent so the bolt hole will be at right angles to the torque tube. Once all of this is done, the lug on the torque tube that the radius rods bolt to will have to be repositioned. Been there, done that.
Don't never get rid of nuthin!
PeteVS is offline   Reply With Quote
Old 08-16-2011, 11:23 AM   #3
blucar
blucar's Avatar
The attachment of the '37-39 radius bars is very simple, that is unless you want to make a big deal out of the process.
As already stated, the bars will bolt right up to the '42-48 axle assemblies. The attachment to the torque tube is very easy if you use a 3/4" spacer (a nut) between the bar and the lug on the torque tube. Of course a longer bolt is required and the spacer nuts have to be large enough for the bolt to pass through with no restriction.
My conversion was the use of a '42-48 Columbia with a late '36 center section and drive line. I used '37-38 radius bars,'39 drums and wheels ... A bolt together application..
Bill.... 36 5 win cpe
Old 08-16-2011, 08:29 PM   #4
PeteVS
PeteVS's Avatar
Think you got it backwards- He's talking about using LATER radius rods on an EARLIER rear.
Old 08-17-2011, 11:48 AM   #5
blucar
blucar's Avatar
Hmmmm? Once I that I was wrong, but I was mistaken..
You are right,, the question was about the shorter '42-48 bars in lieu of my interpretation of the longer '37-39 bars..
Old 08-19-2011, 08:34 AM   #6
Uncle Bob
Uncle Bob's Avatar
Just to give you a reference, the '42-8 measure a nominal 49", the earlier are nominal 66 1/2"
Luck occurs when preparation and opportunity converge.
Uncle Bob is offline   Reply With Quote
