Old 04-03-2021, 03:28 PM   #1
corvette8n
corvette8n's Avatar
Default Help Identify a helmet
Grabbed these from my stash, the one on the right seem to have a separate contact for the points, whereas the left one has what I call a normal points set. I want to try them on my 41 to troubleshoot a no spark problem, seems like the left one is more correct.
File Type: jpg 05AA3985-455B-4B64-9162-F557A6E7D7C2.jpg (60.2 KB, 244 views)
Old 04-03-2021, 04:05 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Help Identify a helmet
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 04-03-2021, 04:21 PM   #3
Veeder
The one on the left is correct for a 41 assuming it has 11A stamped on the cam
Veeder is offline   Reply With Quote
Old 04-03-2021, 04:33 PM   #4
Veeder
Try this again
The one on the left should be the one you use ideally it will have an 11A stamped where the rotor shaft interfaces with the CAM.
Old 04-03-2021, 08:34 PM   #5
38 coupe
38 coupe's Avatar
The one on the left is stock 37-41 (11A marking on the back of the shaft indicates 41).
The one on the right has 32-36 guts installed with the earlier points.I have done this trick a few times myself, I find the earlier shafts and points easier to set up and longer lasting in service. Some of the 37-41 housings have blanked off plug locations that can be drilled for easy point adjustment and allow for 32-36 rubber plugs installed. If you want to take a very long time to rebuild a distributor you can do a lot of work to precisely fit the larger 32-36 rotor and caps into the later distributor.
Old 04-04-2021, 08:04 AM   #6
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Build the one on the left , napa contacts cs47 are great contact sets. clean lube and adjust would be a 11A or a #68 ......
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Thread Tools
Display Modes
