Old 01-15-2020, 06:09 PM   #1
David R.
Default Don’t Laugh, cam nut removal
Alright, go ahead and laugh, my welding is pretty funny but it worked getting stubborn cam gear nut off.
File Type: jpg A6A50DD2-BD09-4ED5-98AB-8BCAEC7B6AF9.jpg (50.0 KB, 364 views)
David R. is offline   Reply With Quote
Old 01-15-2020, 06:15 PM   #2
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Default Re: Don’t Laugh, cam nut removal
Nothing wrong with that!
Old 01-15-2020, 06:41 PM   #3
Redbird
Redbird's Avatar
Whatever works!
Redbird is offline   Reply With Quote
Old 01-15-2020, 07:08 PM   #4
RUNNERBUN
RUNNERBUN's Avatar
I just raced out to the workshop to see if mine was still there. I thought you may have stollen it. It looks just like that.
Adjust your points with gentle blows of a 2 pound hammer
RUNNERBUN is offline   Reply With Quote
Old 01-15-2020, 07:16 PM   #5
Flathead
Flathead's Avatar
Results are what matter.
Flathead is offline   Reply With Quote
Old 01-15-2020, 07:44 PM   #6
Synchro909
Synchro909's Avatar
Mine too but I bent the 6mm plate on a particularly tight nut!
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 01-16-2020, 09:13 AM   #7
rocket1
Looks good,your lucky the nut was not buggered up,most are from a cold chisel.
rocket1 is offline   Reply With Quote
Old 01-16-2020, 11:51 AM   #8
DBrer
Looks good to me, it got the job done that's what counts.
DBrer is offline   Reply With Quote
Old 01-16-2020, 12:13 PM   #9
Purdy Swoft
Purdy Swoft's Avatar
I've had no problem removing the original cam nut with a cold chisel as others have done in the past . I always replace the original cam nut with a new hex nut .
Old 01-16-2020, 12:17 PM   #10
katy
katy's Avatar
This works:
Old 01-16-2020, 06:36 PM   #11
Will N
Will N's Avatar
Agh! It's using a chisel or punch that gets them boogered up so you can't use a proper tool, like you made David, to remove them. The right tool for the right job. I learned that I can still do a backward somersault when I was yanking on the breaker bar to remove a stubborn cam nut and it suddenly came loose.
Will N is offline   Reply With Quote
Old 01-16-2020, 07:56 PM   #12
Synchro909
Synchro909's Avatar
What! Use the right tool and deprive everyone of a demonstration of your gymnastic ability? (And a laugh!)
Old 01-16-2020, 07:57 PM   #13
David R.
With engine removed and on a stand it’s Hard to crowd it enough to get any real leverage. I finally took camshaft gear and all out and clamped gear in vise with shaft supported on sandbags and used ugly tool with the air wrench to get it loose.
Old 01-17-2020, 12:11 PM   #14
katy
katy's Avatar
Using the right tool is all fine and good when one is at home in the shop, but when one is on the side of the road or some other out of the way place "ya use what ya got" AKA known as improvising.
Old 01-17-2020, 03:11 PM   #15
JoeCB
JoeCB's Avatar
The Army Official nomenclature for that process is a "field expedient"
Joe B
JoeCB is offline   Reply With Quote
Old 01-18-2020, 12:27 PM   #16
katy
katy's Avatar
Works for me.
Old 01-19-2020, 02:43 PM   #17
Joe K
Joe K's Avatar
I actually removed mine with a hammer and punch recently. Of course the already buggered up nut was even MORE buggered up afterwards.
Resolve me - buy a new nut AND buy the wrench from the supplier.
So new nut and wrench comes in the same package. Trying the wrench on the nut IT DOESN'T FIT. Only a minor interference and a few minutes with a hand file made it work.
But wouldn't you think SOMEONE would have done a "proof test" to be sure the new wrench works on a new nut? ESPECIALLY if they are shipped in the same package?
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
