Old 11-21-2019, 05:23 PM   #1
dmaxweb
dmaxweb's Avatar
Default Alternate Door Panel Clips for 30 Coupe
The door panel holes are wallowed out to about 3/8" diameter. They will not securely hold the original metal clips. Has anyone found metal clips that will work for the larger hole or modern style plastic clips?
dmaxweb is offline   Reply With Quote
Old 11-21-2019, 08:16 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Alternate Door Panel Clips for 30 Coupe
Weld or braze the holes and re-drill, or just re-drill offset. Maybe bigger clips are out there somewhere.
Old 11-21-2019, 09:01 PM   #3
dmaxweb
dmaxweb's Avatar
The holes in the metal door frame are fine. The problem is the holes in the cardboard upholstery panel that hold the clip heads. The fabric is in near perfect condition and I don't want to make new panels.
Old 11-21-2019, 09:22 PM   #4
dmaxweb
dmaxweb's Avatar
Thinking something like this
https://nam04.safelinks.protection.o...%3D&reserved=0
Old 11-21-2019, 09:53 PM   #5
Tacoma Bob
Tacoma Bob's Avatar
"IF" you can gently pry the fabric back just a bit you might be able to contact cement veneer to the panel. Take a hole punch and make new holes.
Tacoma Bob is offline   Reply With Quote
Old 11-21-2019, 11:17 PM   #6
J Franklin
J Franklin's Avatar
Maybe clear plastic washers under the head of the clip.
Old 11-22-2019, 10:47 AM   #7
jw hash
jw hash's Avatar
the holes in your door are a little over 1/4" the holes in your door panel should be offset to the holes in the door. go on eBay and look up Mopar door panel clips. I have used some similar to item # 323755523366 but are made for a 1/4" hole
jw hash is offline   Reply With Quote
Old 11-22-2019, 11:11 AM   #8
dmaxweb
dmaxweb's Avatar
Thanks John.
Just to be clear, these are the ones on eBay but need to find some for 1/4" hole.
Old 11-22-2019, 12:11 PM   #9
dmaxweb
dmaxweb's Avatar
Originally Posted by dmaxweb View Post
Thanks John.
Doing some searches, it seems the 1/4" were used only on early VW Bus/Campers and some Volvos and are no longer made.
VW parts supplier has the 5/16" but says holes must be slightly reamed out to use them. I really don't want to do that.
Old 11-22-2019, 01:08 PM   #10
jw hash
jw hash's Avatar
that is correct. years back I had found a box of 50 that was for 1/4" they worked great on my A400 and didn`t pucker the upholstery like the wire clips do. even though they are not made anymore they are still out there.
Old 11-22-2019, 03:18 PM   #11
1931 flamingo
1931 flamingo's Avatar
Try Restoration Supply, EsCondido, CA. They have a web
Paul in CTsite.
Old 11-22-2019, 05:36 PM   #12
dmaxweb
dmaxweb's Avatar
Paul in CTsite.
I don't see any upholstery panel clips/fasteners in their catalog.
Old 11-22-2019, 05:48 PM   #13
dmaxweb
dmaxweb's Avatar
I think I will try gluing a strip of wide tack strip material on the back and punch new holes through it.
Then, I need to find some decent clips. I've tried one style from one of the suppliers and 2 different styles from Auveco. Compared to the originals, they are all heavier gauge wire, the wrong shape, too long, or all of the above. I've tried bending and/or shortening with little success. This is partally the cause of the holes widening.
Old 11-22-2019, 08:15 PM   #14
Tacoma Bob
Tacoma Bob's Avatar
You may want to look around with some older auto upholstery shops in your area. They may have some stuff stored away.
Old 11-23-2019, 09:11 AM   #15
1931 flamingo
If you've been thru an Auveco catalog not sure what you're going to do now.
Paul in CT
Old 11-23-2019, 10:38 AM   #16
dmaxweb
dmaxweb's Avatar
Problem solved!
A. I started with Auveco 11406
B. Using a screw driver spread open the "C" head a bit to account for the larger hole in the panel.
C. Cut a small amount off the legs for the top 5 holes so they would not bottom out on the window channel. Taking into consideration the thickness of the panel, only cut off enough to prevent bottoming out or there won't be enough left to grab. May still need need to bend legs a bit.
Out of the box on left, modified on right
Old 11-23-2019, 02:49 PM   #17
Tacoma Bob
Tacoma Bob's Avatar
Problem solved!
Perfect. That's the style I have on hand but with the caps on them. I pry the tops off with a pair of side cutters. Good move.
