Old 07-30-2018, 11:50 AM   #1
fordwife
Default 6 volt radios
Is there a converter available that will allow our old 6volt AM radios to play FM? Or can they be converted? I know they are available for 12v but how about 6v? I like the looks of my original radio and want to keep it.
fordwife is offline   Reply With Quote
Old 07-30-2018, 12:15 PM   #2
flatheadmurre
flatheadmurre's Avatar
Default Re: 6 volt radios
Converting an AM to FM is a major job...either just add a line in to the amplifier part and use an external source like your phone...or go for some kind of aftermarket radio.
There are 6 to 12v step-up converters available at decent prices...just make sure they either have insulated grounds between input and output or you need to keep your new radio from touching the metal of the car.
I just stick a bluetooth amplifier in my cars...the one i use works on 6-24v...then use the phone for radio or spotify.
Old 07-30-2018, 12:32 PM   #3
J Franklin
J Franklin's Avatar
There are shops that rebuild and do conversions like you are wanting. try Google.
Old 07-30-2018, 02:01 PM   #4
34pickup
34pickup's Avatar
I can't use my phone in my car, the cord from the house isn't long enough.
Matt 24:36-41
34pickup is offline   Reply With Quote
Old 07-30-2018, 02:03 PM   #5
zeffer1940
zeffer1940's Avatar
https://youtu.be/annFKTAlF30
My stock 6 volt radio, with a 1970s 12 volt converter, operated by a little 6 volt invertor
zeffer1940 is offline   Reply With Quote
Old 07-30-2018, 03:05 PM   #6
4dFord/SC
4dFord/SC's Avatar
He added FM to the original radio in my 1940 Ford: http://www.billtheradioguy.com/
4dFord/SC is offline   Reply With Quote
Old 07-30-2018, 03:27 PM   #7
tubman
tubman's Avatar
When I was kid, I bought an FM converter for my '51 Ford. It ran on 6 volts and you unplugged the antenna from the radio, plugged it into this thing which had an antenna-like lead coming out of it that plugged into the radio where the antenna usually went. In theory, you tuned the AM radio to an unused station (i seem to remember it was 1440) and you were then supposed to be able to listen to FM stations using the tuning knob on the device. I don't think it worked very well, as I don't remember much more about it, other than installing it.
Old 07-30-2018, 06:16 PM   #8
rotorwrench
rotorwrench's Avatar
It's even getting harder to find a decent MP3 or Ipod player now days. There were several set ups that could interface the MP3 sound through the antenna connection of just about any radio and the radio amp will play it. I'm not sure if that stuff is still around now. Folks just use there I-phones to play music now and most stuff requires an FM modulator or CD interface to connect.
Old 07-30-2018, 08:57 PM   #9
paul2748
paul2748's Avatar
I had the same type of device for my 64 Fairlane - bought it on ebay. Worked pretty good. It was for 12 volts negative ground though
Look on ebay under FM converter or FM radio converter
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 07-30-2018, 09:48 PM   #10
Ken/Alabama
Ken/Alabama's Avatar
I have one if I can find it. 6 volt POS ground. Had it in my 40 about 30 years ago, worked great.
Ken/Alabama is offline   Reply With Quote
