Go Back   The Ford Barn > The Swap Meet > For Sale > Model-A
Old 07-20-2016, 10:33 PM   #1
RHD
RHD's Avatar
Default Front Exhaust Clamp. Special For RHD.
City: Nelson
State: Tasman
Price: 39.95
Manufactured from good quality cast iron. Made stronger that the original with the clamping bolts affixed to one half of the clamp to make installation on a RHD 10 times easier.
Will fit LHD also.
With RHD the steering box is in the way and fitting the original style clamp can be a nightmare. The clamp has to be fitted in exactly the right position as to avoid the clutch pedal shaft. This is normally a 2 man job.
This new clamp is easy to fit and reduces the at times 'choice words' which can be heard when fitting the original style clamp. When fitting, apply a small bead of exhaust sealant inside the clamp, tighten in the correct position and you are motoring. A good flange on the top pipe will aid in the fit of the clamp.
R.H.D.
Author of Model 'A' Ford technical manuals.
Supplier of good original RHD parts.
RHD is offline   Reply With Quote
