Old 08-16-2013, 09:39 PM   #1
Marv 119
Default 32 kinkpins?
I have a new set of kingpins and dont know if they are for a 32 or a model A. Is there a way to tell? They are wards riverside part no 61-4213.
Realy dont want to buy more if these will fit.
Thanks Marv
Marv 119 is offline   Reply With Quote
Old 08-17-2013, 10:39 AM   #2
DICK SPADARO
Default Re: 32 kinkpins?
To determine if your king pins are A or B style place the king pin on a flat surface, cup facing down, The shaft of the king pin will angle upward. From the end of the king pin shaft measure to the level surface. A - king pin measures about .700 while a B- king pin measure .950. The B king pin has a steeper angle but unless you have then to compare it is hard to determine. The 35/6 style, the king pin shaft is almost parallel to the surface.
dickspadaro.com
DICK SPADARO is offline   Reply With Quote
Old 08-17-2013, 02:57 PM   #3
trainguy
trainguy's Avatar
What is a KINKPIN,I am more than a little bit curious!!! LOL
trainguy is offline   Reply With Quote
Old 08-17-2013, 06:19 PM   #4
296 V8
Id given up hope of ever seeing even the slightest bit of humor here …. Thank you
296 V8 is offline   Reply With Quote
Old 08-17-2013, 08:30 PM   #5
Marv 119
Thanks
It looks like i have nors model a king pins.
I think kinkpins are used for getting a afro.
Marv
