07-24-2013, 06:34 PM | #1 |
Pressure Testing Blocks
A few vendors sell the plates and hardware that allows the home mechanic to pressure test a 24 stud block for water jacket cracks. Sets are about $250. Are the kits made well, and will they hold pressure for accurate testing. First hand experience requested please.
07-24-2013, 08:25 PM | #2 |
Re: Pressure Testing Blocks
i think speedway has them
trev,, whats life "TOUGH" whats tough ' LIFE" |
07-25-2013, 03:41 PM | #3 |
I made my own, used a head gasket as a pattern, flamecut the combustion area... Used a cyl head to do the bolt holes myself. Made a real crude looking but functional water pump plate. Object is to be able to hold about thirty pounds of air, use a spray bottle soap/water to look for bubbles.
It should not be a problem for anyones block off plate to hold thirty pounds of air. Mine is made of 3/8" plate and will hold 80 plus lbs. I use a home made rubber gasket... Also- not all cracks leak... Magnaflux also. Karl |
07-25-2013, 10:26 PM | #4 |
½ alum plate - used a head and transfer punch to get the holes - old gasket for chamber shape - hole saws to cut the chamber - made a rubber gasket - same thing for pump block off |
