Old 06-18-2021, 10:13 AM   #1
rfequity
Default fuel dripping out back of carb
So I finally figured out that the GAV wasn't vibrating open, it was just play in the rod. So I tried to set it to drive about 1/4 open yesterday and there was fuel pouring out of the back of the carb where the chock opening is. The drip wouldn't stop until I completely closed the GAV. So it seems like it's either open or not. Maybe something is wrong with the GAV seat?
rfequity is offline   Reply With Quote
Old 06-18-2021, 10:38 AM   #2
jayvee34
jayvee34's Avatar
Default Re: fuel dripping out back of carb
Sounds like your carburetor float needs to be re-set or the float valve in leaking.
IN GOD WE TRUST - SEMPER FIDELIS
John
jayvee34 is offline   Reply With Quote
Old 06-20-2021, 07:16 AM   #3
old31
Does your car want to stall when you slam the brakes on?
Take apart your carb, clean it out and set your float valve. You will need each of these to help you.
You don't want to bend the float tab to adjust the float. Instead, you want to use washers.
https://www.snydersantiqueauto.com/P...earchByKeyword
https://www.snydersantiqueauto.com/P...EL-LEVEL-GAUGE
old31 is offline   Reply With Quote
