Old 06-15-2021, 10:21 PM   #1
bmklawt
bmklawt's Avatar
Default Need someone locally, just bought a model T Touring
Hello
I've always wanted and just bought a 1927 Model T and know very little about Model T's almost nothing. Hoping I can get someone to put eyes on this car and tell me whats the good or bad, whats right or wrong, how do you start it, what should I do before I even try to start and how do you even drive this thing. If anyone is interested in giving a nooby some pointer it would be much appreciated,
Bruce
bmklawt is offline   Reply With Quote
Old 06-16-2021, 01:47 AM   #2
mercman from oz
mercman from oz's Avatar
Default Re: Need someone locally, just bought a model T Touring
1927 Model T Ford Phaeton. Will look good when Restored.
Old 06-16-2021, 11:03 AM   #3
redmodelt
redmodelt's Avatar
This is a long but good read for new T owners;
http://www.mtfca.com/discus/messages/29/8538.html
Old 06-16-2021, 11:18 AM   #4
gz
gz's Avatar
There are LOTS of local Model T Ford clubs in Michigan. Find the one closest to you and join it. This will be your best source of help and support.
https://www.modelt.org/chapter-listings.html
gz is offline   Reply With Quote
Old 06-16-2021, 02:58 PM   #5
bmklawt
bmklawt's Avatar
How do you get the car to freewheel so I can push it in the garage by myself.
Car was just delivered, here are some more pictures.
Old 06-16-2021, 07:03 PM   #6
redmodelt
redmodelt's Avatar
If things are setup correct, pull the hand brake back to straight up and down. This will put the clutch in neutral. (more or less) with parking brakes off. If push come to shove (he he) take the pins out of the brake rods at one end and do same thing if rear parking brakes are dragging. Be sure to have a block or two to put behind or front, as the case may be, to keep the car from rolling on it's own.
Old 06-16-2021, 08:39 PM   #7
JoeBauer
Excellent choice for a first T. Excellent! You are going to love that car!
JoeBauer is offline   Reply With Quote
Old 06-17-2021, 06:09 AM   #8
Rodrelic
Looks ok to me as is. If oil at the petcock and liquid in the radiator I would try to start it.
Rodrelic is offline   Reply With Quote
Old 06-17-2021, 11:32 AM   #9
J Franklin
J Franklin's Avatar
If the oil is old and dirty, change it before you run the car. Even in neutral the car will have some resistance to rolling due to some normal drag on the bands.
Old 06-17-2021, 11:39 AM   #10
CatMan1
Forgive me for asking here, but this has been on my mind for years......what is that little door, or what appears to be a door, on top of the cowl where us Model A people put the gas? I know enough to know that's not where the tank is.
Great looking car in really good shape!
CatMan1 is offline   Reply With Quote
Old 06-17-2021, 12:03 PM   #11
J Franklin
J Franklin's Avatar
The late Ts had the gas tank under the cowl as a FORD better idea!
Old 06-17-2021, 12:30 PM   #12
CatMan1
Oh, Learn something new everyday! Thanks!
Old 06-17-2021, 12:45 PM   #13
redmodelt
redmodelt's Avatar
On Model's T before 1926, some closed models did have a just cowl vent in the same place the gas tank being under the seat. The 4 door after 1926 still had the gas tank under the seat so would have had just a vent on the cowl (you had to get out of the car to fill the tank).
Old 06-29-2021, 08:16 AM   #14
Gary loves Fords
Gary loves Fords's Avatar
The 1927 has a gas filler door on top of the cowl. Pull the parking brake halfway back to get neutral. Where in Michigan are you located. I'm in Waterford Michigan, just West of Pontiac and have a 1927 and a 1909 Model T. I would be happy to help you. Call me at 248-802-7924 Gary
Gary loves Fords is offline   Reply With Quote
Old 07-05-2021, 04:39 AM   #15
NZFordguy
I’d be checking if it had a babbit thrust washer or updated bronze in the diff ��… not much fun if it’s babbit and gives way. As my great grandmother learnt back in the day, and many others since have, its not a fun exercise losing breaking.
NZFordguy is offline   Reply With Quote
Old 07-06-2021, 02:50 PM   #16
redmodelt
redmodelt's Avatar
Some early 20's Overland's and Studebaker's had tanks in the firewall under/in the cowl.
Old 07-07-2021, 01:03 AM   #17
bmklawt
bmklawt's Avatar
How do you go about seeing if it has babbit or bronze thrust washer?
Old 07-07-2021, 06:27 AM   #18
29spcoupe
29spcoupe's Avatar
You have to take the differential apart.
29spcoupe is offline   Reply With Quote
Old 07-07-2021, 11:58 PM   #19
J Franklin
J Franklin's Avatar
Comming soon!
Old 07-08-2021, 12:00 AM   #20
J Franklin
J Franklin's Avatar
In the olden days they had it towed to the nearest Ford dealer and payed a few dollars when it broke, but today it's worth a look if you plan on worrying about it. Just make sure to check when the rear axle gets maintenance.
