Old 01-29-2021, 04:01 AM   #1
cdgray899
Default 1955 center HUD light
Has anyone experimented with adding a center brake light in the deck of their classic? I have a 1955 Customline I'm looking to daily in the summer and want to make the experience a bit safer, but I don't want something too unnatural to the car
cdgray899 is offline   Reply With Quote
Old 01-29-2021, 11:17 AM   #2
56sedandelivery
56sedandelivery's Avatar
Default Re: 1955 center HUD light
If I were doing it I would put it in the back window. Easy to add easy to remove.
56sedandelivery is offline   Reply With Quote
Old 01-29-2021, 01:27 PM   #3
miker98038
miker98038's Avatar
I used a license plate frame with a built in led. It appears chrome when it's off. It's too low to have the full effect, but it's pretty good at night. I've got a 55 bird with both tops, so mounting to the rear window is a problem on the soft top, and nothing with the top off.
I did a rear window brake light on a couple OT cars and I used "box" style that sealed to the rear window. Otherwise I got a lot of reflection off the window. Very distracting after dark.
If you Google third brake light a lot of styles come up.
http://www.taillightking.com/
Go down to the license plate section.
miker98038 is offline   Reply With Quote
Old 01-29-2021, 06:56 PM   #4
Ole Don
Ole Don's Avatar
I used an LED row of lights glued to a chunk of aluminum bolted to the top of the rear window. It lit up the whole inside of the car, reflecting off the inside of the rear window. I added another piece of aluminum under it, to reflect the light outside. That worked great.
Ole Don is offline   Reply With Quote
Old 01-29-2021, 08:39 PM   #5
paul2748
paul2748's Avatar
There are a lot of aftermarket brake lights out there, just look up on ebay or Amazon. As was noted above, any inside unit should be right next to the rear window
48 Ford Conv
56 Tbird
54 Ford Victoria
paul2748 is online now   Reply With Quote
Old 01-30-2021, 11:40 PM   #6
fordor41
fordor41's Avatar
I went to junk yard and checked out 3rd. lights. Settled on a Toyota or Nissan as it was about correct height and angle to match my rear window.about $5
fordor41 is offline   Reply With Quote
Old 02-03-2021, 11:32 PM   #7
cdgray899
Do you have photos? That sounds like it could have a very neat effect
Old 02-03-2021, 11:36 PM   #8
cdgray899
I'm seriously considering doing that. I'll be getting a wire head kit and a ton of wires, I'm sure I could connect a generic connector to the brake wiring harness.
The fun part will be tagging, organizing, And running wires properly. No way I'm going to have a rats nest like some of the cars I looked at before picking up my own!
Old 02-26-2021, 09:02 PM   #9
Lamar Wadsworth
Lamar Wadsworth's Avatar
Even if it's not original, I'm running one in the back window on my '38 Ford pickup and my '55 Fairlane 4 door. I don't even remember what the one in my '55 came out of. It was a couple of bucks at the pick-a-part place. It's mounted on the package tray up against the back glass. It came out of a small 4 door car, maybe a Toyoya, Nissan, or Honda. The black plastic housing is neutral and works with the black interior. Everything from '86 on has them, so the driver behind you is used to seeing them, reduces your risk of getting rear-ended and damaging hard to replace sheet metal.
Lamar Wadsworth is offline   Reply With Quote
Old 02-26-2021, 11:38 PM   #10
fordor41
fordor41's Avatar
just remember that the 3rd light gets power directly from the brake switch, not thru the turn signal, otherwise the 3rd light will blink with the turn signals
Old 02-27-2021, 08:53 AM   #11
58Yeoman
58Yeoman's Avatar
I installed vintage 3rd brake lights that I've found at garage/estate sales. I installed the one in my 58 Chevy wagon near the top of the rear window, and in the 63 Galaxie, it's on the package shelf. They are both mounted against the glass.
58Yeoman is offline   Reply With Quote
Old 02-27-2021, 09:30 AM   #12
Ford blue blood
Ford blue blood's Avatar
My 58 Edsel.....
Bill, certified Ford nut.
2016 F-150
2016 Focus
08 Shelby GT500
57 Ford Ranchero
36 Chevy, 351C/FMX, 8", Mustang II
Ford blue blood is offline   Reply With Quote
