Old 08-12-2020, 03:51 PM   #1
philipswanson
Default Don't Blow Your Battery Tender
I blew my Battery Tender by starting the car with it still hooked up and powered. I suspect a diode blew inside of the Battery Tender from generator current. To avoid this, simply unplug the Tender before starting the engine. Luckily it was still under warranty and a new one is on the way.
Phil
philipswanson is offline   Reply With Quote
Old 08-12-2020, 03:58 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Don't Blow Your Battery Tender
Are you referring to the brand name 'Battery Tender' or a different manufacturer?
Old 08-12-2020, 04:25 PM   #3
philipswanson
Yes, it is a "Battery Tender" brand. It's probably good advice with other brands too.
Phil
Old 08-12-2020, 06:33 PM   #4
glennpm
glennpm's Avatar
Yeah too bad they don’t include an outlet wire circuit breaker for over amperage protection.
Old 08-12-2020, 07:18 PM   #5
leon bee
That's good to know.
leon bee is offline   Reply With Quote
Old 08-12-2020, 07:44 PM   #6
flathead48
Thanks, I have a battery tender and am always starting the car without unhooking it. Thanks again for the heads up.
flathead48 is offline   Reply With Quote
Old 08-12-2020, 09:01 PM   #7
koates
Most standard type battery chargers should NEVER be used as a power supply for testing electrical components such as lights or motors as they are not designed to do this. Some large chargers have the capability to supply a couple of hundred amps for a short period to jump start cars. Battery chargers are just battery chargers ONLY. Regards, Kevin.
koates is offline   Reply With Quote
Old 08-13-2020, 08:03 AM   #8
Frank Miller
Frank Miller's Avatar
I think you may have had a bad unit. There has to be protection for high amp draws. They put out like a 1/a and that is it. Generator current should go to the battery before the tender because that is the path of least resistance. It is a good idea to unplug it first because you do not want to drive off with it plugged in.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 08-13-2020, 08:18 AM   #9
Automotive Stud
Automotive Stud's Avatar
That's probably good practice, I've been known to start the car with the tender plugged in. There is a fuse in the line of the leads that go on the battery. That came in handy for me one time when I was switching the charger to another battery that had a lead on it and mistakenly hooked the two batteries together.
Automotive Stud is offline   Reply With Quote
Old 08-13-2020, 05:28 PM   #10
Step-down
Step-down's Avatar
I’ve seen on BT a line fuse on the positive cable and I assumed it was to stop back feed over load
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
