Old 08-02-2020, 10:22 AM   #1
flatjack9
flatjack9's Avatar
Default 48 truck engine
Has anyone else run across across a 48 V-8 truck engine with studs rather than bolts? I just picked up an engine out of a 48 F-6 2 ton truck. Engine looks like it was never apart. Has standard pistons.This block is also unique as it does not have a bushing for the fuel pump rod. It rides directly in the cast block and there is a very large hole where it intersects the oil gallery. The pump rod blocks the hole. Without it, you would have one huge leak. There is also a plug in the back of the block above the oil drive cover which plugs the back of the oil tube.
Old 08-02-2020, 02:28 PM   #2
KiWinUS
KiWinUS's Avatar
Default Re: 48 truck engine
Jack an 8BA or 59Ab. Canadian 48 trucks shipped to New Zealand had 59Ab engines with studs of course. Interesting engine. Always a new twist with these ole flattys.
Old 08-02-2020, 04:45 PM   #3
Newc
Newc's Avatar
Ditto on the Canadian '48's with new 59AB [C59] mine [M-47] was also a Military block. Newc
Old 08-02-2020, 06:41 PM   #4
flatjack9
flatjack9's Avatar
Originally Posted by kiwinus View Post
jack an 8ba or 59ab. Canadian 48 trucks shipped to new zealand had 59ab engines with studs of course. Interesting engine. Always a new twist with these ole flattys.
8BA. I have found another in my stash with the same characteristics.
