Old 06-11-2017, 12:18 PM   #1
flatjack9
flatjack9's Avatar
Default 36 roadster rear fender
Can someone give me the location of the step pad on the rear fender of a 1936 roadster? Also what hardware is used to fasten it in place. Thanks, Jack
Old 06-11-2017, 04:20 PM   #2
Bursonaw
Bursonaw's Avatar
Default Re: 36 roadster rear fender
Here are a couple pictures that might help. The pad is fastened with a square nut that is rounded in the top to match the inside curve of the fender. Hope this helps.
Sent from my iPad using Tapatalk
Bursonaw is offline   Reply With Quote
Old 06-11-2017, 09:49 PM   #3
Don Rogers
Don Rogers's Avatar
Jack, Here re two images that should help with your roadster step pad. Even though the one sketch is of a 35 rear fender, the dimensions and references should be the same. If you need more information you can contact me at [email protected].
Don Rogers is offline   Reply With Quote
Old 06-12-2017, 01:36 PM   #4
flatjack9
flatjack9's Avatar
Thanks for the help guys. That's what I needed to know.
Old 06-12-2017, 06:00 PM   #5
bigwindowjim
bigwindowjim's Avatar
Ditto that, I needed it too! Thanks Jack
bigwindowjim is offline   Reply With Quote
