Old 08-22-2019, 10:23 AM   #1
50fordcoupeman
50fordcoupeman's Avatar
Default Rule of thumb for fan belt tightness
Is there a rule of thumb that you guys use for belt tightness? This is for my avatar 302 engine. Thanks!!
50fordcoupeman is offline   Reply With Quote
Old 08-22-2019, 12:38 PM   #2
Ford56
Ford56's Avatar
Default Re: Rule of thumb for fan belt tightness
I've used one inch. Seems to work for me.
Ford56 is offline   Reply With Quote
Old 08-22-2019, 12:38 PM   #3
50fordcoupeman
Thank you 56!
Old 08-22-2019, 02:05 PM   #4
bobss396
bobss396's Avatar
I go with trying to spin the alternator pulley by hand. If I can't, it is tight enough. The # of deflection depends on how long that section of belt might be.
bobss396 is offline   Reply With Quote
Old 08-22-2019, 02:34 PM   #5
50fordcoupeman
Thank you!!
Old 08-24-2019, 01:56 PM   #6
Ole Don
Ole Don's Avatar
Mine seemed about right, but with the headlights on during a rain the alternator would squeak. Any tighter and it was hard on bearings.
Ole Don is offline   Reply With Quote
Old 08-24-2019, 08:08 PM   #7
50fordcoupeman
What started this thread is that the bolt that goes thru the alt housing sheared off flush with the head. Sometimes the belt would squeal before this happened. It is a 7/16" by 6" bolt. This allowed the belt to slip significantly so both the alt and water pump stopped working. I lucked out by being able to unscrew the bolt out of the head with my fingers so I think that this bolt was loose. I put in a new grade 5 bolt. I tightened the tension so there is no squeal but the belt is quite tight-maybe a half inch on the longest travel. Is this too tight? Comments please.................
Old 08-24-2019, 08:22 PM   #8
40cpe
40cpe's Avatar
A lot depends on the accessory being turned. On my 272 the AC compressor is turned by the water pump belt. It is not the best situation in my opinion because it has to be pretty tight to run the compressor and I'm concerned about the water pump bearings.
As long as the driven accessory doesn't squeal I would think it is tight enough. The belt can get slick and hardened on the "V" and cause squealing. Check for that.
I had a 5.0 with serpentine belt that was tensioned by a factory tensioner. That joker was tight! I suppose the components were built for it.
40cpe is online now   Reply With Quote
Old 08-24-2019, 09:35 PM   #9
50fordcoupeman
Thanks 40. The belt only drives the water pump and alternator and is a fairly new belt-maybe 400 miles but I will check it anyway. I am thinking it is squealing on the alt pulley since it is the smallest. Maybe it is time for a new belt. Any advice I will try...............
Old 08-25-2019, 06:43 AM   #10
chap52
chap52's Avatar
Not a fix, but a band-aid is to take a bar of soap and carefully touch it to the contact side of the belt while the engine is running. Works to stop the squeal if your on the road. If the belt is still pliable with no cracks it almost has to be a matter of finding the "sweet spot" in the adjustment. I have has a new belt that just wanted to squeal and when replaced with a old used spare I had, the squeal ceased...
I wonder why belt pulleys are smooth and not knurled to better grip a belt?
Chap
Old 08-25-2019, 10:39 AM   #11
darrell
an alternator needs to be tight or it will slip.they are short so the bearings will take a lot more than a generator.you can overdo it and damage the front main bearing but that would take a lot.
darrell is offline   Reply With Quote
Old 08-25-2019, 11:08 AM   #12
dmsfrr
dmsfrr's Avatar
Chap
The belt would wear really fast. Probably not even last a few weeks.
Old 08-25-2019, 11:08 AM   #13
50fordcoupeman
Thanks darrell and chap. I will work on finding the sweet spot some more. Thanks all for the help!!!!
Old 08-25-2019, 11:26 AM   #14
KULTULZ
KULTULZ's Avatar
Post Re: Rule of thumb for fan belt tightness
Universal Belt Tension Gauge - OTC 6673
Don't forget proper belt application/sizing, quality of belt and possible glazed pulleys.
File Type: jpg Universal Belt Tension Gauge - OTC 6673.jpg (4.6 KB, 62 views)
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 08-25-2019, 02:02 PM   #15
JimNNN
Thanks for the belt tension gauge pic, Kultulz. I've been meaning to get one of those, but didn't know what they looked like.
I've used 3/4" total lateral play slack as a standard on my '54. When my car encountered minor charging issues recently, the belt had loosened to 1-1/4" total lateral play. I didn't think that would be enough to make a difference, but when I tightened back up to 3/4" it made a measurable difference in charging. That wasn't the only issue I was facing, but it did help.
JimNNN is offline   Reply With Quote
