Old 08-11-2020, 09:38 AM   #1
Robert/Texas
Robert/Texas's Avatar
Default Model A Missing Badly
My ’28 roadster has been running great until yesterday. I started it in the garage, and it started right up and ran smoothly for about a hundred yards. Then it started missing like crazy as it might if it were starving for gas or way out of time. It didn’t have enough power to drive it back to the garage. I drained the gas tank, replaced all filters and replaced the E-10 gas with E-free gas. I removed the carburetor, checked the float for leakage and adjustment and blew out everything with my air hose. I checked the timing and point adjustment and they were right on. None of this helped.
Any suggestions as what to do next will be appreciated.
Thanks, Robert
Robert/Texas is offline   Reply With Quote
Old 08-11-2020, 09:49 AM   #2
30 Closed Cab PU
Default Re: Model A Missing Badly
If you have a spare condenser - swap.
Pull the plugs and inspect. Perhaps fouled or dirty. Clean and re-gap.
Disconnect the plug leads with the plugs in, space the leads from the plug terminal about 1/8 inch, all equally spaced. Start car, each gap should have a nice blue spark and each gap/spark should not miss.
This hopefully will narrow down if it is electrical/ignition.
Let us know results, try diagnostics to narrow things down before swapping parts/trying things.
30 Closed Cab PU is offline   Reply With Quote
Old 08-11-2020, 10:01 AM   #3
chap52
chap52's Avatar
With it running carefully remove one spark plug wire at a time. Listen, you should be able to identify which plug is not firing properly. If there is a change, it's not that plug. If no change you have narrowed it down.
Now follow the advice from 30 Closed Cab PU
Don't just start replacing things. Find the cause and as always "Enjoy the adventure." Chap
chap52 is offline   Reply With Quote
Old 08-11-2020, 10:06 AM   #4
ryanheacox
ryanheacox's Avatar
I'm currently chasing an intermittent high speed miss. Still checking through the ignition system. 9 times out of 10 a fuel problem is actually electrical.
ryanheacox is offline   Reply With Quote
Old 08-11-2020, 10:16 AM   #5
30 Closed Cab PU
Do you have wireless plates or electronic ignition?
Old 08-11-2020, 10:40 AM   #6
Ernie Vitucci
Good Morning...You might check the distributor body and cap. The bodies can crack and if you can start the car in the garage...you can sometimes see the spark escaping. The little metal connector that rubs on the little tit in the top of the distributor cap can fail to make contact after a few years. Examine the tit for wear and if it looks good bend the metal strap on the rotor and see if the problem is fixed. Also check to see that you have 0.025 thousands between the rotor tip and the four studs that go to the connectors on top of the distributor body. Ernie in Arizona
Ernie Vitucci is offline   Reply With Quote
Old 08-11-2020, 10:49 AM   #7
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Something easy to check is a manifold leak. Get it running and spray starter fluid on the intake gasket area and the manifold itself. If anything changes, that’s your problem. Easy fix. Good luck
Jacksonlll is offline   Reply With Quote
Old 08-11-2020, 11:07 AM   #8
Robert/Texas
Many thanks.
I was thinking that it might be the condenser although I just replaced it about 6 weeks ago with a “Short Proof” one. Sure enough, that was the problem. I had 5 spares, 2 of the old type and 3 of the new. The second one I tried (new type) worked. I think that I need to replenish my collection of these.
Thanks again, Robert
Old 08-11-2020, 11:20 AM   #9
Purdy Swoft
Purdy Swoft's Avatar
I had a similar problem that was caused by sticky new stainless steel valves and guides . It has been said that using new stainless steel valves with new replacement, original style valve guides can cause a sticky situation . After adding a liberal amount of Marvel Mystery oil to the fuel solved the problem . I now mostly add four ounces of Marvel Mystery oil to each ten gallons of gas that is used in the car .
Old 08-11-2020, 12:18 PM   #10
30 Closed Cab PU
Originally Posted by Robert/Texas View Post
Many thanks.
Some run their spares for awhile to make sure they are good. From what others have experienced it is not uncommon for non A and Ls to go bad shortly after installation. A and Ls do not go bad as often.
Old 08-12-2020, 10:00 AM   #11
Will N
Will N's Avatar
I see you are located in Texas. What was the air temperature down there? 100 yards is a short distance to have this happen, but if it was very hot, it could have been vapor lock caused by the fuel boiling in the carb and fuel line.
Will N is offline   Reply With Quote
Old 08-12-2020, 12:21 PM   #12
Jerry in Shasta
Jerry in Shasta's Avatar
Model A Missing "Badly". The last time I saw Badly he hitch hiking down south of town looking to cause trouble, is he still missing? Just had to say it pun intended
Connoisseur of Rust
Jerry in Shasta is offline   Reply With Quote
Old 08-12-2020, 12:23 PM   #13
Jerry in Shasta
Did it run long enough to cause vapor lock?
Connoisseur of Rust
Old 08-12-2020, 12:28 PM   #14
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Have you determined whether it’s fuel or spark???
You can give it a shot of ether after it quits running and if it coughs and briefly fires, it’s obviously a fuel problem.
Old 08-12-2020, 02:53 PM   #15
1928Mik
1928Mik's Avatar
Mine did the same thing last year. Found out the screw that holds the timing cam in place had loosened up. New cam and screw solved the problem for me.
1928 Niagara Blue Phaeton
1972 Olds 442 Convertible
1979 MGB
-Life's Too Short To Drive Boring Cars-
1928Mik is offline   Reply With Quote
Old 08-12-2020, 03:18 PM   #16
30 Closed Cab PU
Post 8 says it is fixed, he had a bad condsenor on a 6 week old short proof replacement condenser.
Old 08-12-2020, 06:13 PM   #17
Patrick L.
Patrick L.'s Avatar
Originally Posted by 30 Closed Cab PU View Post
Post 8 says it is fixed, he had a bad convenor on a 6 week old short proof replacement condenser.
Happens all the time doesn't it.
Old 08-13-2020, 09:24 AM   #18
Big hammer
Many thanks.
Thanks for reporting how you fixed your problem !
get a bigger hammer tap done
Old 08-13-2020, 01:25 PM   #19
McMimmcs
McMimmcs's Avatar
Mine was missing badly and then I looked in my other barn and found it. Not missing anymore !
McMimmcs is offline   Reply With Quote
Old 08-13-2020, 03:56 PM   #20
Patrick L.
Patrick L.'s Avatar
I'm beginning to have the problem too.
