Old 11-24-2018, 11:33 PM   #1
verdirick
Default Windshield gasket on a 30 Briggs Town sedan
I've just replaced the windshield gaskets on my 30 town sedan.. added the hinge gasket as one was missing when I replaced the side and bottom gaskets. Now have zero clearance between the windshield and the gas tank. Did Briggs eliminate the top gasket?? Pain in the Bu-- but see no resolution except to remove the top hinge gasket. Has anyone out there run into this problem with a Briggs 30 sedan??
Rick Jensen
verdirick is offline   Reply With Quote
Old 11-25-2018, 11:19 AM   #2
jw hash
jw hash's Avatar
Default Re: Windshield gasket on a 30 Briggs Town sedan
they all had the top hinge rubber. a lot of times when the header gets replaced, they do not get the header and the header cover installed correctly, the windshield ends up to tight. over the years I have cut down some windshield frames to fit.
jw hash is offline   Reply With Quote
Old 11-26-2018, 08:03 AM   #3
desotoguy
Compare the old gasket to the replacement. Had the same problem with a Coupe. New gasket had the wrong cross section, or shape. Lucky I had saved the old gasket when removed, cleaned it up and installed it and the WS fits.
desotoguy is offline   Reply With Quote
Old 11-26-2018, 08:10 AM   #4
Brian SATX
Brian SATX's Avatar
There are two different styles of gaskets for the area between the windshield frame and car body. They do have different cross sections. One is for a straight windshield and the other is for a slant windshield.
Brian SATX
Brian SATX is offline   Reply With Quote
Old 11-26-2018, 09:24 AM   #5
figment
If you are using a reproduction gas cap it might sit to tall . I used a original and the windshield opened and closed as it should .
figment is offline   Reply With Quote
Old 11-26-2018, 09:57 PM   #6
Cape Codder
Cape Codder's Avatar
Are you sure you have the screws that hold up windshield tight? When tightening those screws it is quite the job but I have seen some that didn't get tightened all the way and therefore it hits the gas cap when opening. ASK ME how I know that! Just a suggestion.
Cape Codder is offline   Reply With Quote
Old 11-26-2018, 10:50 PM   #7
verdirick
Thanks for all the suggestions. Found that the gasket needs to have two spaces removed to let the hinge mate metal to metal with the header cover. Tightening the screws up tight also solved the problem. Of interest, the gas cap is also an original as is most of this unrestored town sedan.
Ie never know what you can run into when you deal with 80 year olds....Fords that is!!
Old 01-01-2019, 12:37 PM   #8
Chiefguy
Chiefguy's Avatar
Hi, I have my first S. The windshield seems to have no hinge. Could that be?
I have some pictures, but don't know how to post them here.
David
Chiefguy is offline   Reply With Quote
Old 01-01-2019, 01:29 PM   #9
burner31
burner31's Avatar
David
Easy way for pics:
Click the "blue post reply" lower left bottom of page, when text box opens, in the top middle of the bar you will see a "paperclip" next to the smiley face, click that, a window will open "manage attachments" click "choose file" then pick your picture, after you picked up to seven pics click the top "upload" on the right hand side of the text box, wait for it to upload.
You must type something, anything into the text box message, scroll down to see "preview post" at bottom of your text box, you should see your message as it will appear when you post, if you like it click "submit reply" to post.
Just make sure the picture file is not to large
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
