Old 08-21-2020, 03:52 PM   #21
daveymc29
daveymc29's Avatar
Default Re: Pitman Arm Question
I have a 29 and a 31 Model A. Both have the shorter pitman arm, from Brattons. On both cars the spindles hit the stops when turned to the full extreme. I haven't noticed any diminished turning radius. I can just make a u-turn at my mail box, could before and after I installed them, no difference, that I could measure, but mine aren't powder coated, that would shorten the radius at least the thickness of the coating X the difference between that and no coating. Perhaps as much as 1/8 inch in the with of the street?
daveymc29 is offline   Reply With Quote
Old 08-21-2020, 10:27 PM   #22
steve smith
Originally Posted by daveymc29 View Post
I have a 29 and a 31 Model A. Both have the shorter pitman arm, from Brattons. On both cars the spindles hit the stops when turned to the full extreme. I haven't noticed any diminished turning radius. I can just make a u-turn at my mail box, could before and after I installed them, no difference, that I could measure, but mine aren't po coated, that would shorten the radius at least the thickness of the coating X the difference between that and no coating. Perhaps as much as 1/8 inch in the with of the street?
My mailbox u-turn is also the same with both pitman arms , but the short one requires less turning and has a quicker road response at high speed(about 60mph).
steve smith is offline   Reply With Quote
Old 08-22-2020, 06:41 AM   #23
SAJ
SAJ's Avatar
I had a shortened pitman arm on my RHD 1930 roadster with 7 tooth box.
The steering hit both stops just as it did with the longer arm.
The box broke so I fitted a 2 tooth box and the steering still hits both stops.
The stop dome nuts both have thick lock washers. Without these the steering radius is tighter but the 550 tyres rub on the brake rods on full lock.
SAJ in NZ
SAJ is offline   Reply With Quote
