Old 08-08-2020, 10:49 PM   #1
daveymc29
daveymc29's Avatar
Default 4 inch drop axle, front for 31 A
Seems to me that several folks have replaced the front axle with a 4 inch dropped axle and taken a leaf out of the rear spring to make their coupes look like the period hot rods had. Where do you find the axle? I was looking at my coupe as it sits and it appears there is 8 inches from the top of my 600 X 16 front tire to the underside of the fender. Close to that on the rear. Any suggestions and thing to not do?
Thanks,
Dave Mc Arthur
daveymc29 is offline   Reply With Quote
Old 08-08-2020, 11:17 PM   #2
jw hash
jw hash's Avatar
Default Re: 4 inch drop axle, front for 31 A
speed way motors has the axles, you want be careful on the drop. it can mess with the tie rod. I have a good contact with them. that is pretty savvy on setting front axles up.
jw hash is offline   Reply With Quote
Old 08-09-2020, 01:30 AM   #3
PotvinV8
PotvinV8's Avatar
https://www.hotrod.com/articles/mode...-adjustment-2/
You're welcome.
PotvinV8 is offline   Reply With Quote
Old 08-09-2020, 10:02 AM   #4
Bob C
Here's an old thread with a lot of info.
https://www.fordbarn.com/forum/showthread.php?t=12576
Old 08-09-2020, 10:42 AM   #5
Jim Brierley
Speedway Motors. Their prices are better than most, and good to deal with. I put a Model T spring in the rear of my widebed. In my tudor I removed the top 4 leaves except for the top one, it is needed as it is contoured to match the cross-member.
Old 08-09-2020, 11:04 AM   #6
Licensed to kill
Licensed to kill's Avatar
I bought mine from "Okie Joe". http://www.joesspeedshop.com/joesproducts.htm He gives a $50 core for your old axle (or will drop yours for you) but I didn't bother as the shipping from Canada would have been more than the core.
Licensed to kill is offline   Reply With Quote
Old 08-09-2020, 11:42 AM   #7
Jack Shaft
Are you running juice or mechanical brakes?
Old 08-09-2020, 02:05 PM   #8
Jack Shaft
Stock A suspension with a "rubber rake"..205/55r16 front,225/75 r16 rear..
Old 08-09-2020, 04:15 PM   #9
Chris Haynes
Chris Haynes's Avatar
By using a '32-'36 front axle and a Posies reversed eye spring I lowered my car 3". You either have to heat and bend the tie rod arms on the spindle or use Jeep tie rod ends to clear the wishbone.
Posies can also sell you a spring that will drop the car 2" by its self.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 08-09-2020, 05:04 PM   #10
wensum
wensum's Avatar
I'm curious about the Jeep Tie Rod ends solution? I have a '32 front axle which drops the front about 1.5 inches, but on sudden bumps, the tie rod taps the chassis and I haven't found a solution to dropping the tie rod 1.5 inches? Any other suggestions that doesn't include goose necking the tie rod?
wensum is offline   Reply With Quote
Old 08-09-2020, 07:09 PM   #11
Jack Shaft
Tie rod function gets dicey the further you are away from the line of the king pin..drop too much below the lower king pin bushing and bump steer increases, the spindle gains leverage on the tie rod.
Old 08-09-2020, 10:10 PM   #12
Chris Haynes
Here you can see the Jeep tie rod ends that drop the tie rod.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 08-09-2020, 11:19 PM   #13
Banger4Sure
Over on the H.A.M.B. nailheadroadster made a number of posts in the summer of 2018 outlining work that he did on his 29... with a very detailed description of how he lowered his car including pictures and a parts list.
https://www.jalopyjournal.com/forum/...my-29.1114472/
Here is what he used for the front:
1) 33 Ford axle
2) 32 Ford spindles
3) 32 Ford spring perches
4) Posies 2" front lowering spring (part # 1002L)
5) Stock Model A Ford kingpins
6) Stock Model A Ford brake actuators
7) Stock Model A Ford shackles
8) Stock Model A Ford wishbone
9) 1/4in spacers (2) These go between the TOP of the axle and the wishbone (VERY important!)
10) 32 spindle bolt bushing (reamed to spindle size after installation)
11) 32 spindle bolt rebuild kit, with new bearings
12) 1 ½” shorter pitman arm (this is not required, but definitely helps to ease steering effort)
In the back he used a Model T spring with couple of leaves removed off the top and a couple of alternating leaves after that leaving him with five T leaves total...
Banger4Sure is offline   Reply With Quote
Old 08-10-2020, 03:53 AM   #14
Johnny Nitro
Johnny Nitro's Avatar
I had Okie Joe drop, and stretch my stock front axle, reverse eye leaf, ‘32 spring perches, and ‘37 Willys tie rod ends, so I could use my stock tie rod. Oh, and a T rear spring
Johnny Nitro is offline   Reply With Quote
Old 08-17-2020, 10:07 PM   #15
wensum
wensum's Avatar
Thanks Chris #12 What I can't tell from the photo is whether the Jeep tie-rod end comes with it's own ball and therefore requires the replacement of the original Model A ball? I have already replaced the balls on the ends of the steering arms with new balls welded in place.
Old 12-29-2020, 07:13 AM   #16
Waksk8n
I’m interested in Jeep tierod question as well. Any more pics?
Waksk8n is offline   Reply With Quote
Old 12-29-2020, 12:18 PM   #17
katy
katy's Avatar
Also, what year(s) Jeep?
katy is online now   Reply With Quote
Old 12-29-2020, 03:34 PM   #18
Chris Haynes
After I posted the picture I found that my supplier had replaced the Jeep parts I ordered with 1948-1964 Ford Pickup tie rod ends. I see that Speedway has them.
https://www.speedwaymotors.com/Speed...nds,50152.html
1921 Runabout
1930 Tudor
Early 1930 AA
Old 12-30-2020, 11:10 AM   #19
katy
katy's Avatar
Thanks
