Old 10-21-2019, 09:06 PM   #1
Eturman
Default Landaui irons
I have a 30 cabroilet 68b that I’m redoing and top parts are a bear to find. My first issue is one of the landaui irons is a little sloppy. Any advice on how to split or correct. I see on a site that it can be sleeved. Any help is appreciated.
Also I’m considering chrome and will probably have to split to do so.
Eturman is offline   Reply With Quote
Old 10-21-2019, 11:38 PM   #2
RandyinUtah
Default Re: Landaui irons
When I restored my 68B Landau irons I split them apart made a bushing and a new rivet out of stainless steel. After plating I
installed the rivet.
RandyinUtah is offline   Reply With Quote
Old 10-21-2019, 11:50 PM   #3
Brad in Germany
Brad in Germany's Avatar
Brattons has a lot of the top parts for Cabriolets including a set of original landau irons, landau iron brackets, landau iron spacers, top clamp, door post caps, landau iron knobs, script door sills, etc, etc...
Here's the link:
https://www.brattons.com/catalogsearch/result/index/?limit=60&q=Cabriolet
Brad in Maryland
Brad in Germany is offline   Reply With Quote
Old 10-21-2019, 11:54 PM   #4
jw hash
jw hash's Avatar
I have done the same as Randy, i make the new rivet real tight in one arm and not as tight in the other. you want arms to be snug when finished.
jw hash is offline   Reply With Quote
Old 10-23-2019, 04:31 PM   #5
Russ B
I squeezed the rivet in a press, and it tightened up sufficiently.
Russ B is offline   Reply With Quote
Old 10-26-2019, 07:48 PM   #6
chiliman
Get with Bill Underwood in Ten he is a Cabby man. Rebuilt my Irons for 68c and lists of parts for me
chiliman is offline   Reply With Quote
