07-16-2017, 09:18 AM | #1 |
1948 F2 vacuum advance question
1948 F2, 226 engine
When I check the function of the vacuum advance, do I just check that it works or should it hold a vacuum? If it should hold a vacuum, how much? I don't recall seeing this info in the book that came with my vacuum pump/gauge setup. Thank you MarkG I have a rebuilt carb coming. It had been on the shelf for a while so might need a little lube. I will see if this help get rid of the dead spot when taking off from a stop.
I know the voices aren't real but damn they have some good ideas! |
