Old 10-21-2021, 07:59 AM   #1
1931 flamingo
1931 flamingo's Avatar
Default generator still motors
Can't find original thread.
V8COOPMAN: I performed step 4 of your list. Re-polorized the gen.
Now what?? All wires on reg are in the right place.
Paul in CT
Old 10-21-2021, 11:52 AM   #2
glennpm
glennpm's Avatar
Default Re: generator still motors
Paul you didn't mention removing both wires from the generator as DD says below:
"With your BATTERY disconnect turned-OFF, can you disconnect BOTH wires from the generator? That should be the smaller FIELD wire on the side, and the larger ARMATURE wire at the rear. CAREFULLY BEND BOTH WIRES so that they will NOT touch anything nearby.
Now, turn your BATTERY disconnect switch back to ON.
Now, is the engine ATTEMPTING to TURN-OVER by itself? IF YES, turn your BATTERY disconnect OFF!
So, did ANYTHING happen?
DD"
Old 10-21-2021, 12:03 PM   #3
1931 flamingo
Yes, it still motored.
Paul
Old 10-29-2021, 02:05 PM   #4
1931 flamingo
On the original thread it was determined that the starter solenoid was shorted. Installed a new one today and it turns over normally. Hooray.
It won't start, I may have "fried" the electronic module.
The journey continues. Again THANKS to everyone that helped.
Paul in CT
Old 10-29-2021, 02:37 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
Paul in CT
Well hey, Paul! Certainly glad to hear that we got your "motoring gen" under control.
As for your NO START situation, what kind of module are you speaking of? What type of distributor are you running? Just understand that I don't do MODULES. Keep us informed with your progress, though. Below is a link to your original thread. DD
https://www.fordbarn.com/forum/showthread.php?t=304960
Click Links Below __
T5 W/TORQUE TUBE
Old 10-30-2021, 08:51 AM   #6
1931 flamingo
V8. It's a Crab with Petronix.
Paul
I want to Thank You for sticking with me.
Old 10-30-2021, 10:52 AM   #7
glennpm
glennpm's Avatar
Paul in CT
Here it is Paul
Old 10-30-2021, 01:26 PM   #8
V8COOPMAN
V8COOPMAN's Avatar
Paul
You're more than welcome. I knew that by getting YOU slowed-down, and with doing ONE methodical test at a time, that WE could get it figured-out. Ya done GOOD! DD
T5 W/TORQUE TUBE
