09-12-2021, 11:13 AM | #1 |
Horn button
Is there a way to clean contact on a model a horn button. It works sometimes and I was wondering if there is a way to clean it.
09-12-2021, 12:06 PM | #2 |
Re: Horn button
Not w/out disassembling it.
09-12-2021, 12:53 PM | #3 |
Re: Horn button
I had a short in the wiring inside the horn that was causing problems might check that also
09-12-2021, 01:24 PM | #4 |
Re: Horn button
My Horn button does the same to, I find that if i put my palm flat on the button and push down and turn my hand back and forth like a windshield wiper, it will work for a couple months . But i do need to remove it and get it good and clean.
09-13-2021, 07:15 AM | #5 |
Re: Horn button
I just filled all the cracks in my steering wheel and painted it flat black, The steel dish (in the center where the nut goes) was cruddy and is now painted. Is it necessary to restore this to bare metal for a good horn ground ? I have a new horn button and repair wire on order.
09-13-2021, 07:44 AM | #6 | |
Re: Horn button
"The more things change, the more they stay the same." |
09-13-2021, 08:28 AM | #7 | |
Re: Horn button
09-13-2021, 05:40 PM | #8 |
Re: Horn button
could it be possible I have grease build up or crud my lightning switch. If I cleaned it and put on contact spray. Do you think that would work. Hate to pull everything apart if I don't have to
