08-27-2021, 11:27 PM | #1 |
Re installing U joint inner & outer clamp set
Hi, Just needing some advice on how the clamp set goes back over the drive shaft tube/ back of gear box for 39 ford?
Also am in need of some parts for my 1939 Ford deluxe if anyone could point me in the right direction, many thanks Paul |
08-28-2021, 12:05 AM | #2 |
Re: Re installing U joint inner & outer clamp set
Are you talking about snap rings?
All you will need is here. Use your phone and call. http://www.vanpeltsales.com/ |
08-28-2021, 12:07 AM | #3 |
Fit gasket over the four studs protruding from rear mount, then the inner hemispherical cover. That covers the universal joint. Then fit another gasket over the four studs. So, now you have a gasket each side of that inner cover. Offer up the torque tube, aligning the uni joint into the driveshaft. Then, fit the outer two halves over the whole kaboodle, ensuring the felt seal is correctly located in the grooves in each half. The four nuts need to be 5/8 A/F, originally castellated nuts, I use nyloc nuts. And a coupla 3/8 bolts,nuts, spring washers hold the two halves together.
08-28-2021, 02:30 AM | #4 |
Fill housing with corn head grease
Lawrie |
08-28-2021, 06:04 AM | #5 |
And, the half with the grease nipple goes on the bottom so you can access said nipple from under vehicle. You can fill the assembly with semi-fluid grease through the speedo drive opening before fitting the turtle.
08-28-2021, 09:12 AM | #6 |
https://www.ebay.com/itm/25125522858...QAAMXQTghRXOy6 Last edited by 19Fordy; 08-28-2021 at 09:31 AM. |
