09-24-2021, 10:43 AM | #1 |
Steering Wheel Slop
I have about 5" to 7" of steering wheel slop on my 29 Roadster. Not sure whatis considered normal and if not where do I start making adjustments?l
09-24-2021, 10:51 AM | #2 |
Re: Steering Wheel Slop
Have someone turn the wheel back and forth while you look at the pitman arm, drag link, steering box. Chances are several components are worn, 5-7 inches sounds like a lot for just adjustment.
09-24-2021, 11:36 AM | #3 |
Yep, as said, check everything for looseness. There is a lot to look at.
What steering box do you have ? The 2 tooth is adjustable. But I doubt an adjustment can get rid of 5". 5" is a lot. I like to see it in the 3/4-1" range. |
09-24-2021, 02:43 PM | #4 |
Thanks for the suggestions, I have a 2 tooth!
09-24-2021, 03:16 PM | #5 |
The best instructions for adjustment are in the Service Bulletins. There are 4 adjustments which need to be done in order.
09-24-2021, 04:07 PM | #6 |
How does it drive down the road? Enjoy. |
