03-24-2017, 07:05 PM | #1 |
How much is it worth?
I am looking at a used LB engine that was running on a engine stand. Oil pressure in the 50's, steady vacuum at 20, temp. normal at 2000 rpm. It is a used engine that was taken out of an early V8, being turned into a resto rod. Sounded great at idle and revving. It does not have AL heads. How much is the LB flathead worth?
03-24-2017, 08:08 PM | #2 |
Re: How much is it worth?
Complete air cleaner exhaust stromberg carb? Including the transmission and radiator
Or just the motor. Something you can drop in and go. $1000 and up. |
03-24-2017, 08:20 PM | #3 |
Boy, I dunno. I sold a '34 engine that ran good for $800 to the first guy who looked at it 20 years ago. Frankly, $1000 sounds low to me.
03-24-2017, 09:19 PM | #4 |
how can you verify it is a real LB with it running?
03-24-2017, 09:24 PM | #5 |
I say 1250
03-24-2017, 09:56 PM | #6 |
03-24-2017, 10:53 PM | #7 |
I was using $1000 as a starting point. Didnt really say what all came with it or if it was a short block ect. Seeing that its coming out of a car being resto rodded it might come with a lot more then just a bare motor. Meaning more $$$ in value
03-25-2017, 08:49 PM | #8 |
I wasn't ever able to sell my running '36 LB. Finally salvaged a few parts and gave it away to get it out of the shop. Anyone who can get a $1000 for one is better at marketing than I am.
John
Houston, Tranquility base here. The Eagle has landed. |
03-25-2017, 11:11 PM | #9 |
Thank you all for sharing your experience and I have a idea what it is worth.
