Old 12-07-2021, 02:14 PM   #1
30A-V8
Default Note to Matt at iron trap garage
On your fathers Ford coupe. Try swapping exhaust manifolds side to side.
30A-V8 is offline   Reply With Quote
Old 12-07-2021, 08:01 PM   #2
Ronnieroadster
Ronnieroadster's Avatar
Default Re: Note to Matt at iron trap garage
Add this to the comments on Matts video
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is offline   Reply With Quote
Old 12-09-2021, 10:29 AM   #3
Ol' Ron
Ol' Ron's Avatar
This requires an adapter plate, but works quite well. Did this back in the 60's for dual exhaust.
G
Old 12-09-2021, 06:44 PM   #4
corvette8n
corvette8n's Avatar
https://www.fordbarn.com/forum/member.php?u=30928
You can private message him click on contact info.
