Old 11-30-2021, 10:55 AM   #1
RB
RB's Avatar
Default 30-31 model 'A' FENDER TO BODY REVEAL
Has anyone used the Snyders quarter reveal repair ? it is listed as a flat panel that requires some shaping to the body contour as it curves around at the rear, it extends 1" above the reveal for welding.
RB is offline   Reply With Quote
Old 12-06-2021, 08:58 AM   #2
RB
RB's Avatar
Default Re: 30-31 model 'A' FENDER TO BODY REVEAL
Just thought I would let anyone that may need the repair panel as mentioned above, Snyders do in fact stock both sides, they were kind enough to send several photo's & dimensions. I do have an original piece & assume the Snyder part would be equally as accurate. I originally advertised for a repair for a 32 5w when I found the model 'A' piece that with a bit of trimming will work fine.
