12-09-2013, 09:38 AM | #1 |
Model A sedan roof insert
Any suggestions on replacing a 2 dr sedan roof with a steel insert, prefer to get a roof section from a junk yard car. Any ideas on what car to use? thanks
12-09-2013, 10:06 AM | #2 |
Re: Model A sedan roof insert
jeep cherokie , late 80s
12-09-2013, 11:38 AM | #3 |
Why would you want to do this? You can buy the inserts from Hot Rod places, but the standard top works well.
If you want a stronger top, The Diablo Model A Club produces excellent videos, available in the Model A club store https://mafca.com/cart/index.php?productID=196 They change the top from the wire, and cloth; to a fiberboard base. The video is well done and easy to follow. |
12-10-2013, 02:52 AM | #4 |
I have known cars that have an all steel top that also has the vinyl on top of that and you would be hard pressed to tell that the roof was all steel.
12-10-2013, 08:49 AM | #5 |
I agree. Lot's of skilled work to do properly. The very first Model A Tudor I owned (late 1970's), a previous owner had welded a steel insert in the top. The vinyl long short grain covering was glued on just like a vinyl top on 70's production cars and was perfect, no leaks and tight as a drum. Steel top insert is very common on street rods. Better to ask that group about donor top piece.
12-10-2013, 09:05 AM | #6 |
Is this the way the "Henry" purist would do it. nope. but it IS my way. he-he. |
12-10-2013, 10:18 AM | #7 |
The trick is to find a donor top with a similar contour (shape), front to back and side to side, as the original Model A top. Don't just use a flat piece as it will not look right and be very noticeable.
Also, if you plan to have an original style interior headliner, be sure to make a plan BEFORE welding in the solid top. If you have rotted top wood or broken bows take care of them first. |
12-10-2013, 10:23 AM | #8 |
The guy that did the body work on my car has a 1928 Tudor that he is hot rodding and he welded a roof section from a Dodge Caravan. I dont know what model year it was from. I can get a picture if you want.
12-10-2013, 01:57 PM | #9 |
I have seen instances of where a guy welded in a steel insert, then proceeded to cover it with vinyl to make it look original. I even know of one guy that did that to his Budd Cab late '31 pickup that came from the factory with a steel top. He thought someone down the line had converted it and he wanted it to "look original"
12-10-2013, 03:57 PM | #10 | |
12-10-2013, 04:08 PM | #11 |
At times I have thought about taking a mold from a roofs of model A's and make a fiberglass insert. that way it would have the grain and it could be painted to have the same sheen as the cloth. some times I day dream a lot.
12-10-2013, 04:36 PM | #12 | |
You sound like Ol'Bill, he NITE dreamed about a COMPUTATOR designed, COMPLETE, fiberglass roof fer yo' HOUSE, Jist squirt a lot uf sticky stuff on yo' roof & set the new one on with a HELICUMKOPTER, & YOU ALL SET! Buster T.
12-10-2013, 05:11 PM | #13 |
It's those fender skirts that make your think that way! LOL
12-10-2013, 05:23 PM | #14 |
He's just trying to hide the white walls
12-10-2013, 10:02 PM | #15 |
