Old 01-16-2021, 03:00 PM   #1
skidmarks
skidmarks's Avatar
Default 3/8" ratchet bead roller Eastwood?
Does anyone remember the sheetmetal bead roller that was hand held and operated with a 3/8" ratchet?
Before the web, eastwood had small catalogs that were the size of the early rod and custom magazine.
I remember seeing this tool and im pretty sure it was Eastwood but it doesnt look like its made anymore. Closest thing i can find online is a seam closer for standing seam roofing.
Maybe im searching with the wrong search names?
skidmarks is offline   Reply With Quote
Old 01-17-2021, 09:04 AM   #2
flatford8
flatford8's Avatar
Default Re: 3/8" ratchet bead roller Eastwood?
Have you tried contacting Eastwood?.....Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 01-17-2021, 10:33 AM   #3
rich b
rich b's Avatar
Could always make your own similar to this homebrew tipping tool.
rich b is online now   Reply With Quote
Old 01-17-2021, 10:45 AM   #4
skidmarks
skidmarks's Avatar
Thats pretty cool. Is the lower wheel a skateboard wheel?
Old 01-17-2021, 02:11 PM   #5
rich b
rich b's Avatar
From the width, I'm thinking it is a roller skate wheel.
Picture's off the net. Was going to make one; but instead used a saw cut in a flat bar to tip the edge.
Old 01-17-2021, 02:39 PM   #6
flatford8
flatford8's Avatar
I like that homemade tool. I got a bead roller but I’m gonna steal that idea for one-off different ones........Mark
Billy Joe Shaver
Old 01-17-2021, 02:41 PM   #7
tubman
tubman's Avatar
There may be a reason why Eastwood no longer has this particular item.
Just sayin'.
Old 01-17-2021, 02:52 PM   #8
skidmarks
skidmarks's Avatar
Just sayin'.
Ok, lets hear it.
Old 01-17-2021, 06:29 PM   #9
tubman
tubman's Avatar
Pure speculation. Most companies do not discontinue successful products for no reason.
In any event, I'd think a 1/2" ratchet would be a better choice, given what it takes to form sheet metal.
Old 01-17-2021, 08:26 PM   #10
skidmarks
skidmarks's Avatar
What i have to do is close up a hemmed edge on a 8 ft long edge of 24 gauge so 2 rollers 1" wide will work even if i have to go over it a couple times. A hand held tool is easier then handling the sheet by myself and try and run it through a bench mounted bead roller. Using a air ratchet is my plan. I just remembered seeing the ratchet powered one years ago.
Old 01-18-2021, 04:48 AM   #11
flatford8
flatford8's Avatar
I think you have a good idea with the air ratchet..... I have an old one that turns slow..... which is good because I don’t move very fast anymore either!....... Mark
Billy Joe Shaver
Old 01-18-2021, 05:34 AM   #12
mercman from oz
mercman from oz's Avatar
That is one very interesting original one-off tool?
Old 01-18-2021, 08:01 AM   #13
Tim Ayers
Back in the 90's, there use to be hand held tool that greatly sped up putting a new door skin on car's door frame. It was called Skin Ease or Ez or something like that. I tried googling it, but nothing came up with those search words.
If it existed then, I'm sure someone improved upon it by now. 24 gauge is lighter than most 18-20 gauge panels, so it should work.
Old 01-18-2021, 09:13 AM   #14
skidmarks
skidmarks's Avatar
Guess its still in production, i was searching under the wrong description . Might be the same thing Eastwood once sold . I remember it as a bead roller instead of a seam closer but thats what i was looking for
Wivco door "skinner"
https://www.autobodytoolmart.com/pro...oor-lock-tools
Old 01-18-2021, 09:37 AM   #15
KiWinUS
KiWinUS's Avatar
How would this work
File Type: jpg 62968AF9-504B-4A36-AC21-AEAA563BF643.jpg (5.9 KB, 74 views)
