Old 02-23-2021, 05:08 PM   #61
Ivan in southeast va.
Ivan in southeast va.'s Avatar
Default Re: Water vs Antifreeze
Prestone LowTox
Ivan in southeast va. is offline   Reply With Quote
Old 02-27-2021, 12:53 AM   #62
darrylkmc
darrylkmc's Avatar
Default Water vs Antifreeze
Water cools better and the Model A engine enjoys its self best when using it, all things being equal, from my experience.
The down side, if you fail to use a Rust Inhibitor, sold as Anti-Rust and Water Pump Lube, ie. Water Soluble Oil, then of course the iron wetted parts will begin to rust.
And most importantly, if the temperature drops below freezing the water will freeze and expand and parts will begin to split open, happens to carburetors and water separators as well.
Anti-freeze offers the best of both worlds, but seems to find leaks and tastes and smells of that sick sweet odor, which I would rather avoid myself.
Around here we mix 70/30 for 60 below f, but even the other way around, antifreeze is only likely to become slushy but won't freeze.
Darryl in Fairbanks
darrylkmc is offline   Reply With Quote
Old 02-28-2021, 08:46 PM   #63
Model A Ron
Model A Ron's Avatar
I would go with coolant year round for all the same reasons.
Ron
Model A Ron is offline   Reply With Quote
