Old 02-23-2021, 07:16 PM   #1
Bazooka Joe
Bazooka Joe's Avatar
Default Steering wheel shim
Would this cause my steering wheel to shake a little at 55- 60MPH+ Looks like they welded one of the studs.
My front tires on my 39 Coupe are a different brand and tire pattern than my rear tires. I also have smaller size and narrower tires in the front than the rear tires. I had a front end alignment done years ago, but do not put a lot of mileage on my car. I had the tires balanced years ago. Haven’t rechecked, balance or alignment since. Yes the drums are from a 40+ Ford
Thank You
Joe
File Type: jpg 2E0C1464-5894-4402-8C22-DCF60279E84F.jpg (61.9 KB, 119 views)
Bazooka Joe is offline   Reply With Quote
Old 02-23-2021, 08:41 PM   #2
Baggs
Default Re: Steering wheel shim
Hey Joe,
Mind PMing me on how you got the image to upload?
Thanks
Baggs is offline   Reply With Quote
Old 02-23-2021, 08:47 PM   #3
JSeery
JSeery's Avatar
Originally Posted by Baggs View Post
Hey Joe,
Thanks
It is almost always a file size issue if you having a problem. Most camera/phone images are way to large to post and need to be reduced to below around 585KB.
Old 02-23-2021, 08:58 PM   #4
Bazooka Joe
Hey Joe,
Thanks
The actual size of the photo did not work, i touched the wording ‘“actual size “ then reduced it, to post.
Old 02-23-2021, 09:00 PM   #5
JSeery
JSeery's Avatar
Here are the size limits.
Old 02-23-2021, 09:41 PM   #6
FritzJr
FritzJr's Avatar
I do not think the welded stud is the source of your problem. If the wheel fits over the stud properly, it should be fine. It is likely that the stud was replaced by someone who did not know the original studs are swedged in place and ended up with a loose stud.
Check your tire balance and toe in. Also check for wheel wobble and tire runout.
FritzJr is offline   Reply With Quote
Old 02-23-2021, 09:45 PM   #7
Bob T
Start with front wheel balance
Bob T is offline   Reply With Quote
Old 02-24-2021, 08:39 AM   #8
Bazooka Joe
Thankx thinking I’ll get the tires rechecked for balance, for starters. No one commented on the front tires being a different brand and tire pattern from the rear, guessing that’s a mute point?
Old 02-24-2021, 08:43 AM   #9
Bazooka Joe
I’ll get them rechecked again as I had them balanced years ago, it’s not like my Coupe is a daily driver. Very few miles are put on car yearly. Wondering if one garage placement of balancing weight would be different than another garages location of the weight. Or are they all spot on no matter where you get the tires spin balanced?
Old 02-24-2021, 11:45 AM   #10
skidmarks
skidmarks's Avatar
Everything you did you mentioned was done years ago.
How old are the tires then getting them balanced would be the easiest thing to do first and rule out.
Potholes and curbs.
Worn out parts and sloppy steering boxes . Dropped axles ect ect
skidmarks is offline   Reply With Quote
Old 02-24-2021, 12:24 PM   #11
Willit Stop
Willit Stop's Avatar
Tires can develop flat spots if they sit for a long period of time. You can jack the front end off the floor about one inch and lay a piece of 2X4 on the floor and slide it till it just barely touches the tread near the center. If there is a flat spot,you'll see a gap when you spin the tire. The fix is easy. Go for a drive that's long enough to warm the tires. This may not be the problem but a possibility. Good luck.
Willit Stop is offline   Reply With Quote
Old 02-24-2021, 01:15 PM   #12
Bazooka Joe
Potholes and curbs.
I’m pretty careful how I drive, can’t say I hit curbs in decades, I do move my car manually a little every week or so to prevent flat spots. I installed a dropped front axle and associated parts years ago and brought to garage to get everything aligned after installing axle years ago. I rebuilt the steering box a few years ago also. I do not drive car much each year, and can’t say I ever hit a decent size pothole.
Easiest and cheapest is getting the tires spin balanced again.
Thankx for the comments and suggestions
Old 02-24-2021, 01:18 PM   #13
Bazooka Joe
Yes I’ll try that, ( jacking car up ) I typically move the car manually every week or so to keep from getting flat spots.
Thankx for the suggestion
Old 02-25-2021, 11:46 AM   #14
Automotive Stud
Automotive Stud's Avatar
I doubt the welded stud would add enough mass to make any noticeable shake, especially being so close to the center of the drum.
Automotive Stud is offline   Reply With Quote
Old 02-25-2021, 12:15 PM   #15
Bazooka Joe
Thinking the same, but I’m not a expert. I can ask when I get the tires spin balanced to see how it ( tires/rims ) differs if any from when I had it balanced years ago. That’s down the road a bit as still in winter mode here..
