Old 02-23-2021, 12:31 PM   #1
Ken hash
Ken hash's Avatar
Default Uploading pictures
I can’t seem to upload pictures. I was wondering if it’s because I’m new or maybe because I’m seventy. I sure enjoy seeing photos of other members projects. I have followed the instructions and picked photo from my pictures but they won’t upload.
Ken hash is offline   Reply With Quote
Old 02-23-2021, 12:38 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Uploading pictures
The problem that is most encountered is that the pictures are at too high in resolution.
You have to determine if you can set your picture taking device to the lowest resolution or use a program to do so to existing pics.
Old 02-23-2021, 01:08 PM   #3
corvette8n
corvette8n's Avatar
If your using windows download Photoscape
http://www.photoscape.org/ps/main/download.php
It lets you save pictures in lower resolution.
If you are using an iPad just crop them in Photoeditor (need to get the app)
This usually makes them small enough to load. Some people have good luck emailing the pictures to themselves it usually resizes them also.
Hope this helps.
Old 02-23-2021, 01:44 PM   #4
VeryTangled
VeryTangled's Avatar
Windows users have a built in app called PAINT. It has the ability to resize photos. .JPG's need to be about 1.4Mb or smaller, I usually set the pixels to about 2400 in the larger dimension.
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 02-23-2021, 02:19 PM   #5
glennpm
glennpm's Avatar
Here are a couple of posts I made, one for windows Paint and the other for an iPhone. You are not alone with this issue!
https://www.fordbarn.com/forum/showp...1&postcount=16
https://www.fordbarn.com/forum/showp...76&postcount=5
Glenn
Old 02-23-2021, 03:18 PM   #6
Ken hash
Ken hash's Avatar
Thanks for the help. I need to learn more stuff. I’ve been taking pictures with an iPhone and air dropping them to my iPad. Once again I appreciate your wisdom.
Old 02-23-2021, 04:13 PM   #7
JSeery
JSeery's Avatar
I have never been able to load photos that large and that is way above the limit stated in the pop-up, which is 585.9 KB. May depend on how you are posting them, I use the thumbnails, and this is the limit I use.
Old 02-24-2021, 08:00 AM   #8
corvette8n
corvette8n's Avatar
Ken here’s the one I use on my IPad, I use the free version, I usually crop the picture and it uploads fine. I did a screen print of the app, cropped it and uploaded it below.
https://www.fordbarn.com/forum/showthread.php?t=246769
I resized the pictures in the link above using Photoscape on a Windows computer, they were all done at once using the bulk resize setting.
File Type: jpg 4BB4E0F0-C006-4EF7-BDE4-C1302793DE59.jpg (35.6 KB, 10 views)
Old 02-24-2021, 01:23 PM   #9
VeryTangled
I know we're all just trying to help. Here's a post from about two weeks ago where I mentioned the file sizes. It looks like 2000 KB is about the limit on .JPG's.
https://www.fordbarn.com/forum/showp...15&postcount=9
full thread: https://www.fordbarn.com/forum/showthread.php?t=294363
-Jeff H
Old 02-24-2021, 01:29 PM   #10
JSeery
JSeery's Avatar
Interesting that works for you and not me. And doesn't match with the limits posted.
Old 02-24-2021, 01:41 PM   #11
VeryTangled
Hi Everyone, One of the less-used forums around here is the Test Forum.
I used it to experiment with resizing the same pic until the file wouldn't upload.
-Jeff H
