Old 11-09-2018, 07:46 AM   #1
oldford2
oldford2's Avatar
Default lesson learned...check the simple things first
I thought you would enjoy my latest.
Last week Barb and I headed out for a trip to Vermont in the old 46 buggy. Stopped to get gas and when I tried to start it all I got was a click from the solenoid. Dead battery?? lights worked so ruled that out.There was a slight downgrade from the pump so Barb got in and I gave it push. She popped the clutch and it started right up. So I stopped at the top of a hill and shut it off. Same thing, just a click. So another jump start and we took it home and went on our way in the Jeep. When I got home I tested the relay and it was doing it’s job. Figured it was the starter so jacked it up, and crawled under and removed the starter. Put it on the bench and it spun fine. So back under to re-install it. No fun for an old guy!
Then, finally noticed a crack in the terminal clamp! It was broken and apparently enough current to run the lights, ignition and relay but not the starter. Put a new clamp on and it started right up. Expand the picture and you will see the clamp break.
John
oldford2 is offline   Reply With Quote
Old 11-09-2018, 08:12 AM   #2
TomT/Williamsburg
TomT/Williamsburg's Avatar
Default Re: lesson learned...check the simple things first
It's always the little thingd that getcha!
TomT/Williamsburg is offline   Reply With Quote
Old 11-09-2018, 09:01 AM   #3
51 MERC-CT
51 MERC-CT's Avatar
Yes, indeed and a build up of oxidation on the terminal and clamp will do the same thing. (had it happen) Needless to say, periodic cleaning was in order after that incident.
Old 11-09-2018, 09:37 AM   #4
37 Cab
37 Cab's Avatar
I never use those clamps. That connection should have a cable with the clamp crimped or soldered. Those cheap clamps are a breeding ground for corrosion and poor connection.
Tommy
37 Cab is offline   Reply With Quote
Old 11-09-2018, 09:41 AM   #5
corvette8n
corvette8n's Avatar
I've had clamps like that bite me also, found a nice heavy cable in tractor supply and replaced the whole thing.
Old 11-09-2018, 12:38 PM   #6
russcc
Excellent recommendation, regular or heavy duty battery cables either soldered or crimped by machine. Someone posted a source for USA made battery cables here recently.
russcc is offline   Reply With Quote
Old 11-09-2018, 12:44 PM   #7
B-O-B
B-O-B's Avatar
I agree with 37 Cab, those are for the scrap pile. Good ones are not that hard to come by.
B-O-B is offline   Reply With Quote
Old 11-09-2018, 01:01 PM   #8
Flathead
Flathead's Avatar
I think that the quality of those replacement clamps has gone downhill quite a bit as well.
Flathead is offline   Reply With Quote
Old 11-09-2018, 01:13 PM   #9
ford38v8
ford38v8's Avatar
Just one of a hundred different examples of poor electrical connections masquerading as something else.
Alan
Old 11-09-2018, 11:04 PM   #10
uncle buck
uncle buck's Avatar
those terminals should only be used as an emergency repair
uncle buck is offline   Reply With Quote
Old 11-10-2018, 12:12 AM   #11
FortyNiner
FortyNiner's Avatar
Good reminder that trouble shooting always starts with the basics.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 11-10-2018, 06:43 AM   #12
chap52
chap52's Avatar
We have all been on those "rabbit trails". It was easier for me to laugh at those adventures when I was in my 20's. You would think that 50 years later I would know better.
Glad you found the culprit, Chap
chap52 is offline   Reply With Quote
Old 11-10-2018, 07:11 AM   #13
oldford2
oldford2's Avatar
So, what is the best terminal clamp to use?
Thanks
John
Old 11-10-2018, 08:18 AM   #14
51 MERC-CT
51 MERC-CT's Avatar
Thanks
John
There really is not anything wrong with the type that you had (they have been used with success for years)
But some want you to install a cable assy that can be fabricated here----
https://www.batterycablesusa.com/00-...s-2-0-awg.html
Old 11-10-2018, 08:25 AM   #15
37 Cab
37 Cab's Avatar
Or you can buy replacement cables from most old ford parts suppliers. Here is an example.
https://cgfordparts.com/ufolder/show...8&g=155&t=1139
Tommy
Old 11-10-2018, 08:59 AM   #16
Licensed to kill
Licensed to kill's Avatar
On my new to me 35 truck, it would just barely turn over with a fully charged battery so I took every ground cable off and the two battery cables and took them to our local John Deere dealer and had new ones made up in "00" cable, all crimped on ends including the battery cables, all made to length. As good as any premade cable and custom tailored (length) for my requirements. BTW, the thing spins over almost like a 12 volt system now.
Licensed to kill is offline   Reply With Quote
Old 11-10-2018, 10:38 AM   #17
RalphM
RalphM's Avatar
These are the best that I have found. Use with Cables that have soldered on terminals, but like all electrical connections have to be clean, and tight.
File Type: jpg 3C4EDD31-55F5-4E81-B060-1E0396508EF8.jpg (15.8 KB, 21 views)
RalphM is offline   Reply With Quote
Old 11-11-2018, 11:15 AM   #18
Brendan
Brendan's Avatar
i replaced the head gasket and new head studs, and a valve lap job also replaced a burnt valve in my A put it back together and tried to start, it turned over fast but would not fire. checked timing and firing order it was right still would not fire. it helps to turn on the gas!
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
