12-25-2015, 04:20 PM | #1 |
Carburetor choices
My 1931 Model A has a Stromberg 97 setup. Runs OK but I want to go back to original as possible. Zenith is more expensive, cast iron. Tilllotson is zinc cast and reasonable. I'm buying new... Just can'r decide on my own as I'm new to owning
a Model A...I'm also going to sell my Stromberg set up... IMG_8460.jpgIMG_0346.jpg |
12-25-2015, 04:25 PM | #2 |
Re: Carburetor choices
You might want to take a look at this one. It is a modern Zenith, model #13922. You can do a search and see what owners think of them.
http://www.autotestsys.com/Merchant2..._Code=ZEN13922 |
12-25-2015, 06:02 PM | #3 |
Welcome Marcel,
Zenith carbs are not that expensive if you buy an original and have it rebuilt. It will more than likely be better than the new ones. That and you can do the rebuild yourself. Just get the jets from Renners Corner-they are flow tested. Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
12-25-2015, 07:00 PM | #4 |
I agree with using an original Zenith. They can be bought inexpensively and easily rebuilt or bought as rebuilt.
The Tillotson and Marvel are good carburetors, but, not original. There were some new Tillotsons being sold for awhile but I think they were troublesome. The newer Zenith's [ tow motor carburetor] look a bit different than an original. |
12-25-2015, 07:08 PM | #5 |
If you want original, the Zenith is the one to get. I have had a few friends buy the brand new ones from Brattons or Snyders with great results.
12-25-2015, 07:54 PM | #6 |
Charlie Stephens |
12-25-2015, 08:30 PM | #7 |
Both Zenith AND Tillitson carburetors are very good carburetors. As Zenith is cast iron, they generally do not warp. A great many Model A drivers, while liking the Zenith, find that the Tillitson carb. performs a bit better and has good reliability. The weakness of older Tillitsons is that they are cast from 'pot metal'; an excellent material for a reasonably long time - but not so good for a long time of aging - warping between the two halves sometimes becomes an issue. Not a critical one, as some file-matching is an easy fix.
I have used a 'properly rebuilt' Tillitson carb. with excellent results for over twenty-five years, and am very happy with it. I also have (on another Model A) used a 'properly rebuilt' Zenith carb. for over 50 years, with excellent results, and am very happy with it. As has been said, the Zenith carb. is what Ford had designed and built for use on his Factory cars. Tillitson is what was widely used as an excellent replacement carb. for over 80 years - so it IS a very good and well liked replacement carb. If it is a 'show car' that you are concerned with, then a Zenith is a MUST. Otherwise, either carb. will work with excellent results. In the end, it really becomes a matter of owner preference, prejudice, and past experience. But with your post saying " I want to go back to original as possible", I suspect that you will want to go with a good rebuilt Zenith carburetor. - Doug Vieyra, |
12-25-2015, 08:59 PM | #8 | |
12-25-2015, 09:01 PM | #9 | |
I agree with this guy. It's easy to do a half-baked job of rebuilding a Zenith--any guy with some goofy-size small wrenches can do it. Many people think that replacing the jets, float bowl shutoff valve, and gasket qualifies as "rebuilding", when often the real problem is in unseen plumbing passages; I think that the jets are seldom the problem, unless they're from previous rebuild attempts. Sad to say, but even "professionally" rebuilt carbs can be a problem. If I were going that route, I would patronize Bert's in Colorado--I have heard ONLY good things about them. Otherwise, I would go with a brand new Zenith 1, which worked a lot better for me than any rebuilt Z I tried. But, it still wasn't good enough during vapor lock season. The final solution for me was the 13922 Zenith carb mentioned above. No more vapor lock or stalling problems! It is also "balanced" for air filter use, if you're that kind of guy. You do have to adapt the fuel line connections, however. Steve |
12-25-2015, 09:02 PM | #10 |
I would love to have that setup. Let me know how much you want for it when your ready to sell it.
12-25-2015, 10:27 PM | #11 |
I'd consider replacing the copper fuel line with a steel one, soon.
______________ Nothing Short of Right is Right |
12-26-2015, 12:17 AM | #12 | |
Regards,
Jeff "Hollywood" Gallagher Sgt. E-4, USAF '72-'76 Honorably Discharged, Honored to Serve |
12-26-2015, 12:28 AM | #13 |
Copper lines are prone to crack from vibrations, steel, not so much.
People will say " I've ran copper for years, and no problem", but why take uneccessary risks? I have had a brass fitting on my intake for the wolf whistle break from vibration stress. |
12-26-2015, 12:49 AM | #14 |
I have a late 30's motorbike with a copper fuel line, and it broke from vibration, which work hardens copper lines.
12-26-2015, 01:58 AM | #15 |
Zenith as mentioned above if your looking for original. I have two As one with a rebuilt Zenith and one with a Marvel. I know this goes against the thoughts of guys that have more experience with A carbs than me but I'll take the Marvel any day. I wish I had another to replace the Zenith on my28. When I go to stop with the Zenith the engine wants to stall. I have to pull the hand throttle on quickly to keep it running. The Marvel starts easy....runs well....very pleased with it. But then again, mine are drivers not show cars. Just my two cents.
12-26-2015, 03:23 AM | #16 |
Recently I rebuilt three original Zenith-1's and spent hours jetting them. The majority of the repro jets in my opinion are just a size or two oversized (all flow tested) and then tested one at a time on the car (time consuming). I was able to dial in two spot on, the third has a problem with the air mixture passage. My A is probably the most reliable running car I have. lol. ps. I picked up several Zeniths for $15-$25 each at swapmeets and club meetings. Join your local car club if you haven't already.
They know enough who know to learn. |
12-26-2015, 07:15 AM | #17 | |
I'm interested too.
1929 A Special Coupe 1926 T Speedster |
12-26-2015, 09:06 AM | #18 |
I am going to go against the tide and recommend you not go with an original Zenith. The model A Zeniths have a design flaw in that the float movement is in line with direction of movement of the car and is effected by inertia. Which can lead to stalling issues when stopping. Some will attest to the fact that playing with the float level can prevent this. However even Zenith felt the problem was serious enough to redesign (rotating the float 90 degrees) their carb for the model B in 1932. Since you are now driving a model A that was built as a good driver not as a fine points car you may not want to fuss with a Zenith to get it dialed in.
I would suggest going with a Marvel carb. It is easily available on E-bay in both rebuilt and not rebuilt forms. While not original equipment, it is period correct, and could be found on many model A's in the thirties, installed by owners who had V-8 envy and wanted a performance boost. Through my research I found that the Marvel was widely praised as the best of the period non-Zenith carbs. My 29 tudor is running beautifully on a Marvel! Here is a link to one: http://www.ebay.com/itm/Marvel-Scheb...Wb2Sn&vxp=mtr" And here is a link to a NOS one: http://www.ebay.com/itm/Model-A-Ford...WfExH&vxp=mtr" Last edited by pgerhardt; 12-26-2015 at 11:49 AM. |
12-26-2015, 10:44 AM | #19 |
Sent you a private message, Friend of mine had a cracked copper gas line,Fire took the whole car John
12-26-2015, 10:52 AM | #20 | |
Did you notice much pep from this setup?? If you want to get a zenith carb to make your engine accurate then you should buy an original zenith carb rebuilt or rebuild one yourself for the fun of it. Don't buy a NEW replicator zenith if you want to kept your original engine! Last edited by FrankWest; 12-26-2015 at 03:17 PM. |
