Old 02-25-2021, 07:51 AM   #1
rockfla
rockfla's Avatar
Default The question of the day?
SO
What would happen IF one tried to start one of our beloved V8 with the battery hooked up backwards.....I.E. Negative ground?
Old 02-25-2021, 08:11 AM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: The question of the day?
Originally Posted by rockfla View Post
SO
You might screw up the ignition or electrical system BUT the starter doesn't care, it's not polarity sensitive and will turn in the same direction.
Old 02-25-2021, 08:13 AM   #3
rockfla
rockfla's Avatar
SO 51Mec-CT
"Screw up" the electrical??? What does "screw up" mean?? what electrical parts???
Old 02-25-2021, 09:48 AM   #4
JSeery
JSeery's Avatar
The coil will work reversed (but weaked), the generator won't work. Did it start? Just attempting to start it shouldn't do much. Install the battery correctly and see if it will start and run.
Old 02-25-2021, 09:52 AM   #5
rockfla
rockfla's Avatar
It supposedly ran for maybe 10 seconds!!!! He said there was "arcing" and I tried to get more out of him on that to NO avail!!!! SO I assume it had to do with my other post on the "Two coil" wiring
Old 02-25-2021, 09:58 AM   #6
JSeery
JSeery's Avatar
Ok, this is a 4 cylinder. Most likely the generator putting out current opposite the battery connection!
Old 02-27-2021, 04:27 PM   #7
fordyford
I used to tell students not to hook up a battery with reversed polarity, it will make the headlights shine backwards!
fordyford is offline   Reply With Quote
Old 02-27-2021, 04:35 PM   #8
J Franklin
J Franklin's Avatar
Does that make the tail/stoplight brighter also?
Old 02-27-2021, 04:49 PM   #9
ford38v8
ford38v8's Avatar
Did they do that in the old days with model Ts going up hills in reverse?
Alan
Old 02-27-2021, 06:08 PM   #10
V8COOPMAN
V8COOPMAN's Avatar
Do ya remember WHY folks went up hills backwards in Model Ts? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 02-27-2021, 06:18 PM   #11
41panelmark
41panelmark's Avatar
Yes, 2 things, possibly has to do with the level of the fuel tank to the carburetor. No fuel pump to push fuel from a LOW TANK to the carb if going up hill. More likely reverse was lower and could pull better than first going backwards.
41panelmark is offline   Reply With Quote
Old 02-27-2021, 06:18 PM   #12
flatford8
flatford8's Avatar
I’ll take a shot.......lower gearing in reverse?.......Mark
41 panelmark types faster than I do.
But now that I think about it the fuel thing makes sense too.
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 02-27-2021, 07:00 PM   #13
Lawson Cox
Lawson Cox's Avatar
How in $%*_) did the question of what happens if you try to start a V8 with the battery hooked up wrong, degenerate into a discussion of a Model T going up a hill backyard????? Inquiring minds want to know. LOL
Old 02-27-2021, 07:10 PM   #14
Pdstark
Pdstark's Avatar
Maybe they back up hill so they can see where they've been rather than where they're going?
As for the original question...starter may not care, other areas might not like it... and the 2nd question, will it continue to run if you disconnect the battery all together?
“Wherever you go - there you are”
Pdstark is offline   Reply With Quote
Old 02-28-2021, 05:15 PM   #15
JSeery
JSeery's Avatar
Ignoring Lawson, My dad always talked about having to back up some hills in his 60v.
Old 02-28-2021, 05:25 PM   #16
Jim in Wisconsin
Backing up a hill puts the motor (carburetor) lower than the gas tank. I think the tank was under the seat, when the level was low it barely ran into the carb.
Plenty of positive ground cars and tractors have had a battery hooked up backwards. The amp gauge reading wrong is a clue that that's what has happened. It can wreck the generator, but the car will run.
Jim in Wisconsin is offline   Reply With Quote
Old 02-28-2021, 05:46 PM   #17
aussie merc
aussie merc's Avatar
when you go up frontwards all you see is the hill Go up backwards and the view is amazing
aussie merc is offline   Reply With Quote
Old 02-28-2021, 06:11 PM   #18
ford38v8
ford38v8's Avatar
Come on Coop, we weren't born yesterday!
Actually, Fathers did it so the kids could retrieve any marbles that fell out of their pockets.
Alan
Old 02-28-2021, 06:12 PM   #19
ford38v8
ford38v8's Avatar
Lawson, did you just call me a degenerate?
Alan
