02-23-2021, 08:34 PM | #1 |
What hub/drum assy do I have here?
N/m, cant get a pic uploaded
02-23-2021, 08:53 PM | #2 |
Re: What hub/drum assy do I have here?
If you wand them upload while you work on figuring out how to post, I'll post them for you. [email protected]
Several threads with detailed, step-by-step instructions. |
02-24-2021, 02:25 AM | #3 |
Thanks,
Seems I need to get a resizing application. Will send you the pic. Thanks again, Mike |
02-24-2021, 04:40 AM | #4 |
I Email them to myself and pick a small size when I send them
02-24-2021, 01:33 PM | #5 |
Yes, the file you sent me was 3.27 MB and the maximum size you can post (per the limits listed in the pop-up menu). This is 120KB. What computer are you using, or are you doing everything on your phone? I also cropped the photo removing the space at the bottom and top.
02-24-2021, 02:21 PM | #6 |
A photo may not tell the whole story. Measurements and characteristics say more than a photo. For example, I can't tell the drum braking surface diameter or the lug pattern size from the photo. An 11" braking surface drum would be later if the pattern is 5" on 5.5". |
02-24-2021, 03:26 PM | #7 |
First, thanks to jseery for posting the pic for me
The BP is 5 on 5.5. I ran a tape on the other side w/o a hub that has the shoes on it, and appears it’s for a 12 inch hub. The shoes are 1 3/4 inches wide. Thanks. |
02-24-2021, 03:30 PM | #8 | |
And again, I thank you for your help! |
02-24-2021, 03:33 PM | #9 |
It's what I'd call a "40" hub. Drum fits over the hub. (Hub is on the inside).
Brakes are 12x1.75" Later had the hub on the outside but off the top of my head I'm not sure where the switch point is. As a point of interest, the hubs/drums as an assembly are interchangeable for any year 1939 to 1948 Mart. |
02-24-2021, 03:46 PM | #10 |
It looks like this 1940 Ford front drum.
02-24-2021, 05:02 PM | #11 |
Your drum pictured below is what I believe to be an "aftermarket replacement" drum/hub assembly for 1940 and '41, like in 19Fordy's pictures above this post. An original '40-'41 drum has these bumps or scallops like in the pic below. DD |
02-24-2021, 06:43 PM | #12 |
Thanks V8 for that tid bit of info.
I always thought the OEM brake drums were smooth like the ones that were on my 40 in 1963. Here is a photo of that same drum/hub assembly. Can you make out the part number. The Ford parts book shows Ford Part Number 01A-1105-A for 1940-41 Ford. Cost was $6.25 for "Hub-Front & Drum". Gee, that was a lot of money in 1940. The Hub-Rear & Drum shows Ford Part # 01A-1115-A and cost $7.50 in 1940. Last edited by 19Fordy; 02-24-2021 at 06:52 PM. |
02-24-2021, 07:23 PM | #13 | |
02-24-2021, 07:44 PM | #14 |
V8: Thanks for the clarification. Your reply made sense to me.
02-24-2021, 08:11 PM | #15 |
I appreciate all the replies, assuming an aftermarket assy, and trying to achieve symmetry, is my best bet for a 40-41 assy?
02-24-2021, 08:16 PM | #16 |
See this current thread: https://www.fordbarn.com/forum/showthread.php?t=294942
02-24-2021, 08:31 PM | #17 | |
02-24-2021, 09:24 PM | #18 |
Thanks,
Issue I have is the other side is without the hub/drum assy, just a spindle and backing plate and brake hardware. I have an hydraulic braked axle out back, but hate to pull it apart as I can't get it in and out of the weather. SO looks like I'm in the hunt for a 40/41 hub/drum assy. Sure wish the swaps would open soon |
02-25-2021, 01:46 PM | #19 | |
02-25-2021, 01:47 PM | #20 |
you should have you're general location in you're avatar, perhaps there is one near home
