Old 06-19-2021, 12:09 PM   #21
Patrick L.
Patrick L.'s Avatar
Default Re: Turn Signals Again
Originally Posted by Oldgearz View Post
I've checked the ground at the switch on the steering column several times. It is grounded.
The flasher doesn't, or shouldn't, need to be grounded. These lites not working or too dim to be seen seems to be a fairly common problem.
Old 06-19-2021, 12:16 PM   #22
Badpuppy
Originally Posted by vangorde View Post
I had an issue trying to run LED bulbs even using a LED compatible flasher. They worked fine with the engine off but flashed erratically when it was running. I ended up replacing two bulbs with incandescent lights and it worked correctly.
Now that's good to know.
Badpuppy is offline   Reply With Quote
Old 06-19-2021, 03:30 PM   #23
Patrick L.
Patrick L.'s Avatar
So did it end up working correctly with the electronic flasher or a thermal ? I think it was the electronic, but...
I think the electrons from our monsters are too dirty for some of these new fangled thingys.
I'm assuming yours is 12v.
Old 06-19-2021, 08:13 PM   #24
[email protected]
modela@aol.com's Avatar
This p/n 84787 solid state positive ground flasher from LEDLights.com solves most issues discussed. It is a three terminal can with an external flying lead that has to be grounded out to your A.
modela@aol.com is offline   Reply With Quote
Old 06-19-2021, 08:40 PM   #25
[email protected]
https://youtu.be/9iLfk08JMYc
YouTube video on this flasher unit.
Old 06-20-2021, 08:58 AM   #26
Patrick L.
Patrick L.'s Avatar
Many, or all, the electronic flashers do have an ground wire. I was talking about a thermal flasher.
I think I have 3 electronic flashers that claim they are supposed to work, they don't. So I just use rear LEDs with high candlepower incandescents in the front with an old preferably NOS 535 flasher. New chinese made thermals are junk.
There are now new 6v positive grd electronic flasher that supposedly work, but, I haven't needed try any.
Old 06-20-2021, 10:17 AM   #27
dlfrisch
dlfrisch's Avatar
PatrickL. - Like I corrected……buzzer.
dlfrisch is offline   Reply With Quote
Old 06-20-2021, 11:09 AM   #28
Patrick L.
Patrick L.'s Avatar
I know, Post #19
