Old 06-05-2021, 07:44 PM   #1
Andy
Default 32 brake lever sector dimension
I would like to modify a Model A brake lever sector to use on a 32. The A part has the pivot hole 1.75” below a line thru the mounting holes. I need the dimension for a 32. Thanks!
Andy is offline   Reply With Quote
Old 06-05-2021, 08:24 PM   #2
DavidG
DavidG's Avatar
Default Re: 32 brake lever sector dimension
See post #8 in the thread "32 emergency brake lever" further down the first page in this forum showing the Model A and '32 sectors side by side. If the pawl has been punched out of your Model A sector, it looks as though there isn't room for the hole you wish to make.
Old 06-05-2021, 09:46 PM   #3
Andy
I was not going to move the lever pivot hole. I was thinking of moving the mounting holes down. I think I can play with the photos by cutting out the shape of the 32 sector and compairing it to the A sector. The A lever is in bad shape so I am not working with a rare desirable part.
Old 06-05-2021, 10:17 PM   #4
tomcarman
tomcarman's Avatar
I have an original complete '32 E brake handle. See thread below. Can you sketch which exact dimension you need and I can measure it. Tom
https://www.fordbarn.com/forum/showthread.php?t=298862
tomcarman is offline   Reply With Quote
Old 06-05-2021, 11:15 PM   #5
deuce lover
deuce lover's Avatar
Here is the one CW Moss sells for $12.95
deuce lover is offline   Reply With Quote
Old 06-06-2021, 08:14 AM   #6
Andy
Tom, I would like you to put a straight edge across the centers of the two mount holes and measure to the center of the pivot hole. It looks like it is a small distance. It does not need to be super accurate. Thanks
Old 06-06-2021, 08:56 AM   #7
Mart
Mart's Avatar
Andy I can do this for you. Give me 10 mins.
Ok.
My best guess would be 1/8". The center bolt is 1/8" above the mounting holes.
In the pic the center bolt is centered on the edge of the wood bench top.
Old 06-06-2021, 10:15 AM   #8
Andy
Thanks, That is perfect.
I finally realized what the funny lighting hole in the middle is.
That is where the paul was stamped out!
I would love to help you sometime if I can.
Old 06-06-2021, 11:15 AM   #9
DavidG
DavidG's Avatar
While you're looking, please note which side the teeth are on, which precludes moving the mounting holes as there is only thin air where they would move to on the Model A sector in replicating the '32 hole pattern.
Old 06-06-2021, 11:39 AM   #10
Andy
I will take care!
Deuce Lover,
THANKS, I sure was unaware of it being repo'd.
Thread Tools
Display Modes
