10-04-2019, 05:20 PM | #1 |
Backfire
Hi, I'm new to Ford Barn, please be patient with my question. I have a 1951 Ford woody, flathead V8. My dad bought the car new and gave it to me when I turned 16 in 1966 and said here is your car. I have had it ever since and know every squeak and rattle. It's been running rough lately and I have done everything I know to "tune" it. Last Saturday when I started it up. I forgot to turn on the key before I started turning it over. Obviously there was a lot of un-burned gas in the exhaust system. As soon as I turned the key there was a loud "explosion". From the new sound of my car, I realized that I had obviously blown a gigantic hole in the muffler (thank you Midas for another free lifetime muffler).
The question: Where do I start with the diagnosis? Obviously start with the timing. Advance? Retard? Check the vacuum system. Rebuild the carb? Also - anyone know of a good flathead mechanic in the Orange Co., CA area? Thanks! Thanks. |
10-04-2019, 05:32 PM | #2 |
Re: Backfire
How much do you know about how the distributes work on these vehicles? Sorry if I am telling you what you already know! The distributer is totally a vacuum advance unit that works off of a vacuum source in the carburetor. A possibility might be the diaphragm in the distributor, the vacuum line, the vacuum source from the carb, etc.
10-05-2019, 05:32 AM | #3 |
Re: Backfire
Try a new condenser. My 50 had a backfiring problem also. A neighbor said replace the condenser. It turned out that the wire in the condenser was partially connected.
10-05-2019, 09:26 AM | #4 |
Re: Backfire
Sent PM
Rich |
10-05-2019, 10:34 AM | #5 |
Re: Backfire
A lot of things can cause a rough running engine. Without knowing what has already been done, it's harder to give a good course other than a complete tune up and possibly some needed fuel system maintenance. Time and modern fuels aren't kind to older automobiles. The two previous items are a good start. One being the easiest thing to check and the other being one of those things that would need to be checked when higher than normal coolant temps and poor performance show up. It could be something as simple as old fuel that has deteriorated to the point that it's noticeable.
When troubleshooting start with the easiest thing first then go on to the progressively harder checks until the problem shows up. Welcome on the Barn. |
10-05-2019, 01:10 PM | #6 |
Re: Backfire
10-09-2019, 09:35 AM | #7 |
Re: Backfire
It was an exhaust backfire. Not an intake backfire. The power valve could still be bad for other reasons. Not an exhaust backfire.
Sal |
10-09-2019, 10:29 AM | #8 |
Re: Backfire
agree with this statement...thks
"I believe God is managing affairs and that He doesn't need any advice from me. With God in Charge, I believe everything will work out for the best in the end. So what is there to worry about". Quote by Henry Ford |
10-09-2019, 11:37 AM | #9 |
Re: Backfire
Welcome to the ‘Barn.....great suggestions so far....you stated you did what you know to tune it....what was that??.....when I have a new problem, I go back to the last thing I did to see if I made an error on something....ignition and fuel system maintenance is a good place to start but be methodical while diagnosing (as has been suggested)....
So, you have a ‘51 Woody that your father bought new and you’ve owned for more than 50 yrs.?!?!?!?......that’s fantastic!!...Good for you on keeping it all these years!!!....We LOVE pictures.....please!!.....Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
10-09-2019, 03:11 PM | #10 |
Re: Backfire
How old are the spark plug wires? if they are old , you could be getting "leakage" out of one or more wires , causing a misfire. if this is the case, sometimes this problem can be seen at night with the eng. running, the hood open and all the lights off. some times you can see the wires arcing back and forth. the best way the average guy can check for bad plug wires is with an ohm meter, if you have one. there is usually a spec in some manuals of how many ohms per foot of plug wire is allowed. this will also depend on the type of wires. can't remember the spec's off hand . I am sure some one here knows.
10-09-2019, 03:29 PM | #11 |
Re: Backfire
Thanks everyone! I did put in a new rotor, condenser, coil, points, etc. a while back and it worked o.k., but ran rough. Last week I disconnected the vacuum line (as it says in the manual) and tried my best to set the timing using an old timing light that is not very bright (I ordered a new induction one that I can hook up to a 12 volt source which will be more accurate). I did find that there was no gap on my contacts and fixed that which made it better, but did not fix the overall problem. It seems to idle o.k., but starts chugging during acceleration, so I'm thinking the vacuum advance or power valve. I will work on those. By the way the carb is a fairly new Edelbrock 94 and "should" be working fine, at least it was when I installed it a few years ago.
My dad bought the car in Kermin (Fresno), CA for $2649.87 on March 10, 1951 and gave it to me in 1966, 53 years ago. I know pretty much every rattle, squeak and "her" (sorry not PC) every complaint. Sometimes "she" just decides not to start, no matter how much coaxing I use. I'm on my 3rd or 4th engine due to blown head gaskets and cracked blocks, etc. Who knows, I may be in the market for another one. |
10-09-2019, 03:31 PM | #12 |
Re: Backfire
I did install new wires probably 3-4 years ago, but I will check. Thanks
10-09-2019, 03:40 PM | #13 |
Re: Backfire
Nice wagon! Are you sure the vacuum advance is working? With your new timing light you should be able to check that.
10-09-2019, 03:43 PM | #14 |
Re: Backfire
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 10-09-2019 at 06:39 PM. |
10-09-2019, 04:54 PM | #15 |
Re: Backfire
Boy, Is that a nice lookin' vehicle. I have the original invoice for my '51 Club coupe somewhere. I think it was almost a thousand dollars cheaper. I'll see if I can find it.
10-09-2019, 05:02 PM | #16 |
Re: Backfire
Is the Edelbrock 94 fully compatible with the loadamatic distributor?
10-09-2019, 05:24 PM | #17 |
Re: Backfire
That's a beautiful '51 Woodie ! That was a lot of money back in '51. My Father bought a new '63 Dodge 440 with a 318 V8 for $2400. About $200 less than the '51 Woodie.
Sal |
10-09-2019, 05:46 PM | #18 |
Re: Backfire
Jimmy VD......great looking wagon!!!...thanks for the pics!!...you’ve come to the best place for help with your car...as has been said you should see the timing mark move when you rev the motor if your advance is working. If the gap wasn’t right on the points, and the motor was run, it may have burnt them and they should be checked closely. Keep us posted of your progress.....Mark
10-09-2019, 06:20 PM | #19 |
Re: Backfire
WOW Jimmy, what a GR8 woody ! Welcome to the barn & keep at it; you'll get it figured out. mike
10-10-2019, 10:48 AM | #20 |
Re: Backfire
Also, when it's idling, does the exhaust stink like too much fuel ? If the idle improves when you turn in the two idle mixture screws on the carb, then a good chance the power valve did go bad. Or the fuel level is too high for some reason.
Sal |
