05-21-2016, 07:42 AM | #1 |
41 Ford ammeter remains at center / generator charging?
I did a test where I checked battery voltage post to post and it read 12.4V Started car and revved engine - redid post to post test and vintage was 13.8-14.9 volts - so I suspect the 12V gen is working. Question Should the ammeter raise above centerline if battery is fully charged ? Last season the ammeter needle would move to slightly to right of center at mid throttle application, though this season the needle stays put in the center now (though it still dips slightly left when lights are turned on) Last edited by 1963turnerjohn; 05-21-2016 at 08:21 AM. |
