Old 06-25-2018, 02:31 PM   #1
1963turnerjohn
1963turnerjohn's Avatar
Default 1941 Ford car steering box part #
Hello
Can anyone confirm the proper Ford # in a 1941 Ford steering box?
I saw a box with # 21A-3550-M3 and need to determine if it will be proper for my 41 Super Deluxe.
Thank you,
John
1963turnerjohn is offline   Reply With Quote
Old 06-25-2018, 03:04 PM   #2
Joe Immler
Default Re: 1941 Ford car steering box part #
I believe the prefix 21A refers to 1942 Fords. The prefix 11A is found on 1941.
Joe Immler is offline   Reply With Quote
Old 06-25-2018, 03:06 PM   #3
1963turnerjohn
Thank you - any idea on interchangibility ?
Old 06-25-2018, 03:39 PM   #4
grumppyoldman
grumppyoldman's Avatar
I'll go with Joe, my 41 looks like yours, minus the skirts, same color too.Just put the wide whites on it last week. Is there someone in your area that can overhaul your gearbox? Al
grumppyoldman is offline   Reply With Quote
Old 06-25-2018, 04:03 PM   #5
1963turnerjohn
Well I’m trying to keep cruising in her and change out quickly - the rebuilder here has 3 week leadtime
Old 06-25-2018, 06:43 PM   #6
rotorwrench
rotorwrench's Avatar
The steering gear box & shaft only (no column tube parts or pitman arm) likely started life as an 11A part but the replacement for it was the 21A-3504 and was used from 1941 thru 1947. Casting numbers on the gear housing are likely individual part numbers for the casting. I'm not sure what changed for 1948 (likely the lock went away) but they all share the 11A-3524 steering shaft with the lock hole in it. There is a lot of interchangeability there.
Old 06-25-2018, 06:45 PM   #7
V8COOPMAN
V8COOPMAN's Avatar
He careful here. The two gearboxes are essentially identical, but it seems like I remember the '42-'48 shafts being longer. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 06-26-2018, 06:43 AM   #8
Terry,OH
Terry,OH's Avatar
21A-3550 is not in my parts books?? What is it?
Old 06-26-2018, 09:53 AM   #9
Bob C
It's just the steering gear housing.
Bob
Old 06-26-2018, 11:56 AM   #10
V8COOPMAN
V8COOPMAN's Avatar
Bob
A "-3550" is just the steering gear housing in Ford-speak. The "21A" refers to a date (1942), and a 221 cu in Ford engine (1), and passenger car application (A). DD
T5 W/TORQUE TUBE
