05-10-2021, 11:28 AM | #1 |
40 Ford Convert Woods
I recently bought front and rear woods from Wesscott. The rear wood is notched along the length for what I'm guessing is for the rubber for stapling the top. My question is does the the notch face forward or to the rear of the vehicle. I have no references and Wescott doesn't know they just sell it.
Any help Guys Thanks Frank |
05-10-2021, 11:49 AM | #2 |
Re: 40 Ford Convert Woods
Frank... photos please. I've done a number of convertible restorations but can't understand what you are referring to.
The top bows?
"I can explain it for you. However, I can't understand it for you". Last edited by Kube; 05-10-2021 at 01:20 PM. |
05-10-2021, 12:12 PM | #3 |
Faces towards the rear.
05-10-2021, 01:40 PM | #4 |
Yes the rear top bow. Ill see if it will photograph.
05-10-2021, 04:08 PM | #5 |
I've never heard them called "woods" so was confused.
Ken has already figured out what you were asking (He's much smarter than me) and has answered correctly. There is no rubber fit to that relief in the bow.
05-11-2021, 08:44 AM | #6 |
05-11-2021, 08:55 AM | #7 | |
Are you planning on installing a new top? I've attached two photos of a '39 I'd installed a top upon. It should give you a better understanding of the process.
05-12-2021, 02:54 PM | #8 |
Yes I'll be putting a new top on but probably not until next spring I still have so much to do on the vehicle. I already have a rear glass window and frame for it.
I also need to know how high up from the beltline does the rear bow go? Also there is no tacking strip in the relief on the rear bow? Thanks for all the help. |
05-12-2021, 04:07 PM | #9 | |
I'll try my best to check tonight for the dimension you desire.
05-19-2021, 11:19 AM | #10 |
Thanks All
