03-21-2018, 05:21 PM | #1 |
Cadillac transmissions in vintage hot rods
I hope that there are some old-school hot-rodders out there that can help me with some information.
I'm looking at a '37 Ford hot-rod that was built probably 30 years ago using some '50's era (maybe ?) speed parts. The car has Fenton intake, aluminum heads and some other vintage speed stuff on a '50s Mercury flathead. My question is that the car has a non-synchronized 3 speed in it, and the guy told me that it is either a Cadillac transmission or a Ford case with Cadillac gears in it. I don't know if this was ever really done, or if the trans is just worn out. Is anyone familiar with this set-up? Is (was) there such a thing? I would think that a Cadillac would have syncros in it unless it was really, really old. I'm not sure if I want to mess with having to double-clutch, and speed match gears to downshift with this type of tranny. Any information would be appreciated. I really like the car, but I don't want to get into something that I'll regret later. Thanks |
03-21-2018, 05:30 PM | #2 |
Re: Cadillac transmissions in vintage hot rods
Did you try asking this question on the HAMB?
03-21-2018, 05:32 PM | #3 |
I looked on the HAMB, but I've always gotten good info on this forum.
03-21-2018, 05:37 PM | #4 |
Common to see lasalle 3 speeds cut off and adapted to closed ford drive shafts. And there was a flathead to lasalle /cadillac/50 olds transmissions. 37 lasalle was the only factory floor shift the rest were side shift.
They did have a 2nd-3rd syncro and its the weak point. The roadmaster buick was also adapted to closed ford driveshafts. Both have to have the output shafts resplined to a ford ujoint and then the case redrilled and some bolt holes plugged for the flathead transmission mount Most likely its a worn out flathead 3 speed. They did not put cadillac gears in a ford case. Its no were close to fitting. Lincoln gears in a ford case, yes and that more likely whqt he has or think he has. These was a thing called a X case that used chevy gears in a aftermarket case and they a re pretty rare |
03-21-2018, 05:43 PM | #5 |
That's a great suggestion, I'm going to try it.
Thanks! |
03-21-2018, 06:48 PM | #6 |
03-21-2018, 08:26 PM | #7 |
Just curious. But can you get under and take a picture and post it on here. Probably not but hey,,,,,worth a try.
03-21-2018, 08:35 PM | #8 |
Cadillac and LaSalle top shifters trans' were the go to units when the hot rodders started using the new OHV's like Olds and Caddy
03-21-2018, 08:44 PM | #9 |
Yup - here's an example of a 39 Ford Coupe with a 37 LaSalle floor shift trans in place behind a 51 331 Cadillac power plant (click picture to enlarge)
03-21-2018, 09:52 PM | #10 |
cool! looks like you could "drop the pan" on the lasalle to clean out all the mashed up gears! (damn kids)
03-21-2018, 10:19 PM | #11 |
I ran a 39 Caddy LaSalle box behind a 354 Hemi and you could syncro upshift 1-2-3 but only 3-2 downshift. A dead give away for identifying whether or not its a caddy is that access to the gears is from the bottom of the case. The following HAMB article has some good info on these transmissions. https://www.jalopyjournal.com/forum/...d-view.151009/
03-22-2018, 07:58 AM | #12 | |
Thanks for that. I have a 38-41 and I am always looking for more info on them. Searched the hamb before, but never seen this article. |
03-22-2018, 08:11 AM | #13 | |
remember caddy's being used. Maybe they are the same?? G.M.
www.fordcollector.com |
03-22-2018, 08:39 AM | #14 |
Difference is tail shaft length and then the lasalle line was drop so it was just cadillac and the one year only 50 olds which is the most desirable next to the 1937 floor shift version
03-22-2018, 09:42 AM | #15 |
My Brother had a 1940 La Salle coupe. He drove it as his family car for many years, and he drove it from Ontario to Vancouver three times, in the early sixties. It was finally scrapped, but before that he sold the Transmission to as local, as they had such strong gears.
We used to park The La Salle and my Ford pickup together in our parents driveway, before he Joined the Air Force and moved away. Cheers, Byron.
IT'S NOT YOUR AGE, IT'S YOUR ATTITUDE ! |
03-22-2018, 10:07 AM | #16 | |
I have a 38-50s side shift that Ive just been saving/storing for no reason. Haven't done any research on it to get actual yr/s. |
03-22-2018, 11:44 AM | #17 | |
03-22-2018, 12:36 PM | #18 |
Why do you say this? The H.A.M.B. is a board for Traditional Hot Rods, and what could be more traditional than a LaSalle transmission behind an early Cad or Olds in a Hot Rod? Or am I missing something?
03-22-2018, 01:55 PM | #19 | |
Post #2: Did you try asking this question on the HAMB? The HAMB should be the best source there is on this type of question! Also a typo I corrected!!!!!!! Last edited by JSeery; 03-22-2018 at 02:00 PM. |
03-22-2018, 02:06 PM | #20 |
OK. One little word can sure make a difference! Now your corrected post makes sense.
