10-15-2016, 05:53 PM | #1 |
Big R has coolant for $6.99 gallon
Needed some today and saw it was $2 off a gallon so its $6.99. Gallon jug of green stuff concentrate, Durex brand.
http://www.bigr.com/search.aspx?tSearch=coolant
1929 Model AA - Need long splash aprons! |
10-16-2016, 09:15 AM | #2 |
Re: Big R has coolant for $6.99 gallon
What make 'extended life' coolest different? Or extended life oil for that matter?
10-16-2016, 10:26 AM | #3 | |
From what I found you want an inorganic coolant for your older car, not the newer "Organic Acid Technology, OAT (Extended Life anti-freeze). I also read NOT to use extended life anti-freeze if you have a copper/brass radiator. Maybe someone can shed some light on this for us? I am using PEAK "Green" which states on the label "for all cars 1989 and earlier". Here is a link to just one of the articles that may amswer some questions. http://classiccars.about.com/od/main...Antifreeze.htm Last edited by Y-Blockhead; 10-16-2016 at 11:11 AM. Reason: Add Picture |
10-16-2016, 04:21 PM | #4 |
"Big R" what is Big R?
10-16-2016, 05:34 PM | #5 | |
Location: Barren windswept mountain somewhere in bleak Northeastern Pennsylvania
I wouldn't be so paranoid if people weren't plotting against me all the time |
10-16-2016, 06:46 PM | #6 | |
