10-15-2021, 08:47 AM | #1 |
Canadian Intake Question
I picked up this intake @Hershey, and found the oil fill neck fracture m a buddy of mine. 59ab big truck cab over maybe?
Anyway, anyone know of a breather cap, stock or otherworldly de, I can use? We f anyone has one for sale or can sell me, send me a message. Thanks! |
10-15-2021, 09:15 AM | #2 |
Re: Canadian Intake Question
I don't know what originally came on it, but it looks like a Corvair oil fill cap might work. No venting in the Corvair cap, it just seals the tube. Corvairs vented through the push rod tube o-rings, just kidding.
10-15-2021, 09:21 AM | #3 |
Thanks, Zeke - will check it out ….
10-15-2021, 11:02 AM | #4 |
Tom .....I love those manifolds. As "handy" as you are at fabricating, here's a suggestion. Take one of these '63-'65 Corvette oil-fill tubes (available at all of the Vette outlets), along with this "twist-on" cap, cut that two-foot-long pipe down to some reasonable height, 'glue' them together....voila! You could even utilize the little HOSE connection for a PCV Valve, or not. The last picture shows what a Canadian friend of ours did with his similar manifold. He has mounted a PCV Valve below the plate. DD . |
10-15-2021, 11:06 AM | #5 |
There is actually what could almost be called a tapped in hole for a PCV valve in this manifold.
Thanks so much for the ideas! |
10-15-2021, 11:10 AM | #6 |
10-15-2021, 11:10 AM | #7 | |
This is the ONLY picture that I have showing the stock CAP. DD |
10-15-2021, 09:42 PM | #8 |
Thanks so much, gents - I would like to use some version of the front fill pipe and incorporate a PCV valve. It all depends on the diameters of the Corvette and Corsair fill pipes vs the little over 1” OD of the stock pipe to see how much of a slice and dice it’s going to be ….
10-16-2021, 12:19 AM | #9 |
Plain twist on petrol cap for a v8 should fit. that's what I have on my oil filer tube which is on Canadian Aluminum manifold.
Gb
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
10-16-2021, 06:19 AM | #10 |
I might have one
10-16-2021, 06:21 AM | #11 |
I’ve seen at least 2 different types.
10-16-2021, 08:28 AM | #12 |
Caps, one locks external and the other internal.
10-17-2021, 11:06 PM | #13 |
I have the external locking cap style - first pic top left cap. If you would like to sell it please pm me. Thanks!
10-18-2021, 08:04 PM | #14 |
10-19-2021, 11:35 AM | #15 |
10-19-2021, 12:01 PM | #16 |
10-19-2021, 12:48 PM | #17 |
I would argue that the problem was the material selected for the o-rings rather than the design of the tubes. Once Viton o-rings became available the problem was solved. The design was most likely driven by cost. The VW tubes and seals are much more robust.
10-19-2021, 09:27 PM | #18 |
I worked at a Chevy dealer when Corvairs still roamed the streets, don't get me started.
10-20-2021, 08:46 AM | #19 |
10-20-2021, 03:39 PM | #20 |
