Old 10-03-2021, 05:33 PM   #1
russcc
Default EV8 Parts at Hershey
City: Bourne
State: MA
Price: In ad
EV8 Parts – Hershey
The parts are from the Michael Dingman collection, Mr Dingman was on the Ford Motor Company board of directors for 20 years.
’32-34 Spindles w/king pins - $75
’32-34 F & R hubs & drums, B-1106, B-1126 - Sold
’32 cowl light mounts - $15.
’35 jack & handle - #$40.
’35 head light lenses, Ford script, re-pop
’35 standard outside door handles, original - $15.
‘36 68-3580 steering box, restorer rebuild - $175.
;36 column drop w/key - $75.
’36 68-6050 cylinder head, NOS
’36 Oil pan, appears unused.
’38-39 column drop w/key - $75.
’37-41 helmet dist, complete w/good rotor - $65.
’37-41 3 bolt timing cover, NOS - $45.
;38 serial # 78 case, excellent condition - $145.
’38-39 swan shifter complete w/cap, spring etc - $75.
‘39-41 complete pre-bent brake lines, and all hoses, new - $75. set
‘39-41 F & R brake backing plates, restored w/hardware & shoes - $75. pair
’39-41 6 blade, balanced crank mount fan, NOS - $60.
’40 O6H-LZ, 18T main drive gear - $85.
’40 O6H LZ, 24 T 2nd gear - $80.
“40 Lincoln 3 speed transmission, restorer rebuild, LZ 18T MD, 24T 2nd.
’40-48 brake drums, O1A/21A-1125, new replacements, 3&¼” ID - $75. ea.
’41 hood hinges, pair
’42 pass hub caps, ’46 p/up, new - $25. pair
’42-48 2 bolt timing cover, NOS - $75.
’42-48 dual temp sender O1A-1099, NOS - $65.
’42 1GA coil converted by Skip to 12V, new rebuild - $95.
’46-48 D & R brake backing plates, restored - $40, pair
59AB – stock cam, stock bearing journals - $50.
Miscellaneous;
Vintage Stewart Warner 160 MPH speedometer
94 Holley carb, rebuilt
Set of 8 Manley Performance SS flathead valves, 1.600”
Cole Hersee HD battery kill switch
Chrome steering column mast jacket
‘58-62 C1 Corvette front bumpers, pair
’65 Porsche retracting ash tray
Located in Chocolate Field North, C4S-35 from Wed.1PM to 4PM, Thursday & Friday 9-4 weather permitting. PM me if you would like me to hold parts for P/up. My cell phone # will be posted C4S-35.
russcc is offline   Reply With Quote
