07-08-2021, 08:59 AM | #1 |
Rotten Rotor from Rotorville!
Here is an interesting one. Has anyone ever come across this before?
I came across that #2 cylinder was not firing. Exchange plugs, distributor cap, metal wires, and still the same issue. All dist bumps were at .025. I changed the rotor and they all fired. I didn't believe it so I installed the old rotor again and #2 was still dead. Went back to the new rotor and they all fired. How is it possible that a rotor could always pick one node not to fire. Confused in Rotorville |
07-08-2021, 09:20 AM | #2 |
Re: Rotten Rotor from Rotorville!
Try a new cap; swap plugs/brass plug contacts?
07-08-2021, 09:24 AM | #3 |
07-08-2021, 10:26 AM | #4 |
07-08-2021, 11:03 AM | #5 |
Look at the orientation of the rotor. Swap back and forth to see if the brass arms point in different directions. This is the only thing I can think of.
07-08-2021, 12:19 PM | #6 |
07-08-2021, 01:20 PM | #7 |
Soooo what's the gap between rotors and body, my guess old one is a wider gap.
07-08-2021, 01:38 PM | #8 |
07-08-2021, 08:32 PM | #9 |
Check the points gap on each lobe to make sure the whole 4 are opening evenly. Sometimes replacement stuff in the 70's wasn't made that well.
